aftermarket tach question - Nissan Forums : Nissan Forum
Old 05-16-2012, 04:53 PM
Anyone have a link or any suggestions how to install an aftermarket tachometer with shift light in the 03 sentras, i imagine its the same diagram for the gxe as any others (including se-r and spec v) and does anyone know if their a cluster that goes above 140 mph for these cars, we were gonna put an se-r cluster in sense the speedometer keeps hitting 120 and rolls over back to 10 LoL
Nissan Altima 2000 gxe (manual)
AEM WAI (short ram)
Strut bar
Modded VTC synalloid
Full ecm tune up programmed
Painted the valve cover and some other parts
Wire tucked.
current project:girlfriend restricted >.<
current repair: mystery check engine light(havent had a chance to run code..thought it was the temp sensor I put in *sighs* another problem....)
Nissa Sentra 2003 GXE (q18 went to the heavens...sr20det swapped)
Full custom fab exhaust.
Turbonetics 6085 (at 20 psi)
Forged street pro piston
Street pro (stage 5= cams)
Street Pro stage 3 clutch (she grinding alittle into 3rd)
New special computer (gonna tune after turbo still been doing motor work)
strut bar
Custom fabricated pod WAI, breather Intake.
New Fuel pump/fuel cell(buddy wont tell me what he used)
17's rims
lowering springs
Swaybar bushings
High performance camber/caster kit.(custom fab)
JDM Smoked headlights
8k blue HID's (xenon high/low)
432 HP to the wheels (before boost)
*priceless*
Current project:
Current repair: Still trying to figure out how to install tach gauge. Paint Job. Finishing install of header and permanately attaching turbo. Still need to re-tune after we complete the turbo as a permanate fixture, he had to custom weld and build a header running 4-2 sense the boost wasnt working right on 4-1, will post final WHP when Hondata runs the dyno again.
