Changing spark plugs - am I wrong? - Nissan Forums : Nissan Forum
post #1 of 19 Old 12-26-2010, 12:47 AM Thread Starter
Went to change my spark plugs yesterday and... wth? Do you seriously have to remove the manifold to get at the plugs??!! I can't see any other way to get at them.
Anyone done this? Advice? Tips?
Also, what's the life on the plugs? I got a lemon engine and got a brand new one around 12k, but I don't know if they replaced or reused things like plugs (my guess is they reused). I'm at 20k now. It still idles and runs smoothly.
jcasetnl is offline
post #2 of 19 Old 12-28-2010, 12:30 AM
Import Tech.
SHAWN's Avatar
Plugs are due every 105,000 miles , and yea they can live that long ... Yes, you have to pull the intake manifold, so you will need the manifold 0-rings ...Its a super easy Manifold to remove ...
Use only NGK plugs on these and they are Platinum , spend the extra for Iridium, they tend to hold up better ...
SHAWN
Auto Shop Northwest O.C. OR
'09 Sentra FE+ Driver
'14 Crosstrek Wifes
'98 Sentra SE Time Attack
'09 Titan CC LB SE
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #3 of 19 Old 03-01-2011, 03:20 AM
hatori18's Avatar
spark plugs
would you need the same ones for a 07 sentra s. 2.0
hatori18 is offline
post #4 of 19 Old 03-01-2011, 03:22 AM
hatori18's Avatar
saprk plugs
would you need the same ones for 07 sentra s 2.0. thanks
hatori18 is offline
post #5 of 19 Old 03-01-2011, 03:41 AM
SoCalSentra's Avatar
The plugs might last 105K miles but if you leave them in that long they can be a bear to remove.......and if they're a 2 piece plug they can break! (don't know if they are, just saying)
I'd have the plugs taken out at no more than 75K miles, but that's me.
Shawn....why do you say to only use the NGK plugs? If you can find another brand plug in the same "heat range" they should be ok shouldn't they?
SoCalSentra is offline
post #6 of 19 Old 03-02-2011, 08:10 PM
hatori18's Avatar
were to find
Were can I find spark plugs for a 07 sentra I went to NGK website and they didn't have anything available for that model. I also called pepboys and they didn't have it available to. Thank You.
Also do you have to replace the plugs if so were can i find them.Sorry I'm new to this car but i love it.
Thank You.
hatori18 is offline
post #7 of 19 Old 04-11-2011, 07:44 PM
Import Tech.
SHAWN's Avatar
I say use NGK , because you will get the best performance, mileage , etc. from the NGK plugs . I have seen issues when using some other brand plugs in most Japanese imports ...
'07 MR20DE up to 7/'09 have the same plug # ... # PLZKAR6A-11
I have done a bunch of Nissans with 105K + on the plugs and have never had an issue ( another reason to use NGK ) ... Some car brands ( Ford for one ) is known for hard to get out plugs , but I have yet to see an issue with the Nissans .... But if your really concerned its a pretty easy plug change so just do it when you want ... I will probably do my wifes '09 at 90K ...
SHAWN
'14 Crosstrek Wifes
'09 Titan CC LB SE
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #8 of 19 Old 03-27-2013, 02:09 AM
rev
Quoted: 1 Post(s)
Will also be attempting this job on my car. Several posts mentioned the need for intake and throttle body gasket, are these required. Having trouble sourcing them.
allsentra.com-A Nissan Sentra Forum/Sentra Se-r Forum/Sentra Spec-V Forum. All Sentra's(B13,B14,B15,B16 and B17 welcome reguardless of motor or typeView topic - How To: Change MR20 sparkplugs.
rev is offline
post #9 of 19 Old 04-01-2013, 12:02 PM
Throckmorton's Avatar
Quoted: 96 Post(s)
What is a "2 piece plug"? I don't recall ever seeing any of those.
Throckmorton is offline
post #10 of 19 Old 06-03-2013, 03:00 PM
rev
Quoted: 1 Post(s)
Do you guys put anti-seize on the plugs? Most people say it is not needed as the head is aluminum. But what about an NGK plug, is it steel? I mean if it won't hurt anything then might as well put a bit on, no?
rev is offline
post #11 of 19 Old 06-03-2013, 04:47 PM
the FORD F150 with the 3 valve 5.4 TRITON uses a MOTORCRAFT 2 -piece plug that cracks in the middle body of the plug when you try to change them.
if you don't leave them in for 100,000 miles it's less of a problem but some still break......check out the pages of complaints on F150 forums from people who had to pay $1,500 or MORE for a plug change at the dealer because when they crack they charge you more money PER plug for labor. When they crack you have to use a special tool to get the plug out of the head and if pieces fall into the head MORE LABOR!
FORD has like a 10 page bulletin on how to change the plugs......you have to soak them, quarter turn, let em sit, quarter turn ect.....and they still can break.....piece of crap design of a plug.
post #12 of 19 Old 06-03-2013, 06:23 PM
rev
Quoted: 1 Post(s)
That's brutal why would they continue to use cheap plugs as such. The dealership should cover the extra charge since it's their design. Is this design the same in current trucks?
rev is offline
post #13 of 19 Old 06-03-2013, 08:55 PM
No, best not to as they already have what is effectively an anti-seize coating.
http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
Didn't used to be the case, of course, and lots of people continue to use anti-seize whether they know about this or not.
If you are careful not to over-torque I suppose no harm done and you may have added insurance that they will come out easy the next time.
But if you err on the low torque side, then you run the risk of a bad seal or even the plugs starting to back out in use.
Take your pick. I'd vote for no anti-seize I think.
macnut is offline
post #14 of 19 Old 06-04-2013, 12:33 AM
Quoted: 5 Post(s)
OOHHHH boy, so true...
Did spark plugs on a Triton engine,biggest pain in the ass job... I will never forget the last back 2 on the drivers side..
2009 Altima coupe 2.5 6spd; my babe!
Amsoil synthetics, LED lights, illuminated kickplates, WC Lathewerks shift knob, Racing Line STS/TB kit/strut bar/RSB/ front & rear end links/ first 4th gen 2.5 with racing Line springs, first 4th gen to swap 7th gen maxima brakes (on 16" wheels).
-Plans for now/future:restored old school wheels in progress/ quad projector retrofit in progress.
Best 1/4 mile; 15.598@88.3MPH factory stock to the tires.
DD/work ride; 2000 Nissan Xterra 4WD V6 5spd
-Damn thing has a taste for blood and all my time, bringing him back to life= taking my money
Wade01 is offline
post #15 of 19 Old 06-04-2013, 12:55 AM
Quoted: 96 Post(s)
Thanks for the information. Not being a Ford man, I never knew about the plug problems on the 5.4 Triton.
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN SENTRA / 200SX / SE-R FORUMS > B16 2007-2012 Nissan Sentra Discussion (SE-R / Spec-V)
