Radio Screen/Dashboard Dead and Won't turn on - Nissan Forums : Nissan Forum
Old 11-28-2012, 02:53 PM
Smile Radio Screen/Dashboard Dead and Won't turn on
So this has happen a few times. I get in my car and the Radio won't turn on, the lights and other electronics are working. However the power button wont' turn the radio on, its dead. Only a few hours later after I get back in my car it will come back on, all the stations presets and clock reset. Now its been off for a whole day. I have a Nissan Sentra 2010 S, its the factory radio. Is this an electrical problem, warranty doesn't cover the radio from what I was told on the phone this morning. Should I get a custom radio? Advice needed thanks.
Old 11-29-2012, 12:36 AM
702L32's Avatar
iTrader: 5 reviews
if u still have a warranty see if you can get it replaced. it could be something as simple as the ground not making contact. nissan is notorious for electrical problems. u can upgrade to aftermarket if u want but u want to know why the stock one is not working first.
Old 11-29-2012, 06:06 AM
^ sounds like a grounding issue with the oem head unit. Usually the wire is connected to a flimsy little bolt. When I had my aftermarket single din head unit put in, my local car audio shop said they had to go in further in the console cavity to find a better piece of metal to bolt the grounding wire to
2009 2.5s with Takeda sri, Stillen front strut brace, 6k HIDs, black matrix depo tails, glossy black roof vinyl, LED drls.
future mods: lowering springs, Racingline or Stillen rear sway bar, 4 channel amp, catback exhaust, better rims
Old 11-29-2012, 06:11 PM
Thanks turns out a friend said to try to replace the audio fuse. I did. And now it works $2.00 fix. Not bad
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN SENTRA / 200SX / SE-R FORUMS > B16 2007-2012 Nissan Sentra Discussion (SE-R / Spec-V)
