help!!! headlight issue - Nissan Forums : Nissan Forum
post #1 of 9 Old 01-09-2017, 02:06 AM Thread Starter
Brix B16's Avatar
Quoted: 1 Post(s)
hello, I'm new to the forum and I hope I'm placing this in the right section. I'm having a problem with my headlight and I'm wondering if anyone else has had this problem as well. I have a b16 and my passenger low beam does not work, I checked fuses and changed the bulbs. still nothing works. I have inspection coming up soon and don't want to fail because of that. please help. thanks in advance
Brix B16 is offline
post #2 of 9 Old 01-09-2017, 02:25 AM
d0ugmac1's Avatar
Quoted: 650 Post(s)
More of an Altima Gen3/Gen4 guy, but the headlight relay would be my first guess.
Nissan OEM HIDs with Morimoto bulbs/harness, RacingLine FStB & RSwB @ 200%, ETI LED Fogs,
Altima FSMs & Useful posts: Bose Upgrade / Alternator / Bad Ground / Rear Brakes / TPMS Reset /
/ Spurious ABS / Audio Power / ABS Diag / Steering Lock
d0ugmac1 is online now
post #3 of 9 Old 01-09-2017, 04:26 AM Thread Starter
Brix B16's Avatar
Quoted: 1 Post(s)
I'm going to try that. I just figured that a relay would cause both to not work. its just funny because I have both of the hi beams working but just one low beam that works. ill try anything right now though. thanks
Brix B16 is offline
post #4 of 9 Old 01-09-2017, 01:34 PM
d0ugmac1's Avatar
Quoted: 650 Post(s)
I missed the single bulb out bit...sorry. You are correct, there is only one relay for the LB and two (one each ) for the HB. See page LT-8 for more detail.
I assume it isn't just a bad bulb? Did you try switching bulbs from left to right? Inspect the bulb socket...sometimes bad connections eventually burn out.
post #5 of 9 Old 01-09-2017, 02:22 PM Thread Starter
Brix B16's Avatar
Quoted: 1 Post(s)
yes I tried switching the bulbs and even bought new bulbs at first
Brix B16 is offline
post #6 of 9 Old 01-09-2017, 02:59 PM
d0ugmac1's Avatar
Quoted: 650 Post(s)
Ok, and even though there is only one relay, each LB is fused separately. Did you check/swap the two LB fuses in the IPDM?
post #7 of 9 Old 01-09-2017, 09:49 PM Thread Starter
Brix B16's Avatar
Quoted: 1 Post(s)
yes, I added new fuses in the ipdm.... starting to wonder if its a ground
Brix B16 is offline
post #8 of 9 Old 01-10-2017, 01:44 AM
d0ugmac1's Avatar
Quoted: 650 Post(s)
Do you have (access to) a DVM (digital multimeter)? You can check for 12V at the connector when the lights are supposed to be on. The other side of the connector should beep if you do a continuity test to ground (or if you cannot do that, it should show 12V from it to the +ve terminal)
post #9 of 9 Old 01-10-2017, 07:19 PM Thread Starter
Brix B16's Avatar
Quoted: 1 Post(s)
I don't have one but I did just order one, two days ago. hopefully it works, if not the I'm going to become an Altima guy lol. I just found one for sale and it has all the bells and whistles
Brix B16 is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN SENTRA / 200SX / SE-R FORUMS > B16 2007-2012 Nissan Sentra Discussion (SE-R / Spec-V)
