Remote start troubles. starts then shuts off. - Nissan Forums : Nissan Forum
post #1 of 11 Old 01-15-2006, 10:48 PM Thread Starter
When I remote start my car, the car starts, and runs for 10-15 seconds then shuts off. Any Ideas? 02 Altima, Autocommand remote starter, DEI 556U Bypass.
Thanks in advance
02altima3.5se is offline
post #2 of 11 Old 01-15-2006, 10:56 PM
Burning Up
Jesus's Avatar
no tach input?
1994 Nissan Altima SE
1974 Datsun 260Z
Jesus is offline
post #3 of 11 Old 01-15-2006, 11:19 PM Thread Starter
no i did not hook up the tach wire, i didnt know it was necessary. Where should i connect it to?
post #4 of 11 Old 01-17-2006, 05:40 AM
the newb
WarX's Avatar
i was about to say....didn't you email this question to me...then i realized that i PM'd yah back at 10pm yea, the tach wire is the problem. as i said in the pm
WarX is offline
post #5 of 11 Old 01-17-2006, 03:44 PM Thread Starter
warx where in mass are you from? Im from Cumberland, RI. Thanks again for your help. It says that the tach wire is located at the ECM behind the glovebox but I cant find the ECM. Do you know how to access it?
post #6 of 11 Old 01-17-2006, 04:59 PM
A Hole
you can also connect it to an injector wire
YouCantCatchMe is offline
post #7 of 11 Old 01-17-2006, 11:42 PM Thread Starter
thanks for the heads up on the injector wire but i think it will be easier to splice it in within the car instead of running a wire through the firewall.
post #8 of 11 Old 03-09-2006, 08:44 PM
Check and see if the unit is seeing the transponder(key). The 556u should be checked first. Remove the ring put you key in the ignition and remote start it, if it keeps running then the car is'nt seeing the key in the bypass.
DaBetts is offline
post #9 of 11 Old 03-09-2006, 09:12 PM
Kenny@Infiniti Massapequa
Da Mayor's Avatar
it's either the tach wire has to set or the key lost its coding. those are the only two options i see that is wrong.
KENNYATINFINITI@aol.com [lease retention manager @ infinitiofmassapequa.com][cardomain: onephatalti]
'06 G35 6MT Sedan w/ plenty of toys... '02 Altima V6 sold 8/2/06 [TSZ33.com Shift_27]
Da Mayor is offline
post #10 of 11 Old 03-09-2006, 11:20 PM
I usually hook up the tach either at the ECM or behind the guage cluster on the tach wire. Both usually work, but you just need to measure the voltage on the wires to make sure.
Honorary Syracuse Altimas.net and NYssan.org Member
JLewisinSyr is offline
post #11 of 11 Old 03-09-2006, 11:29 PM
I'm so old school
wickedsr20's Avatar
iTrader: 7 reviews
That would be my first guess also.
Has this remote starter stopped working or is this a new install?
Tach wire is another possibility if this is a new install.
Running the wire through the firewall shouldn't be too much more trouble since you should already have wires through for the siren and the hood pin.
'03 Altima V6: totalled - R.I.P. - forever missed
07 Jeep GC SRT-8: debadged, Trufiber c/f hood, Volant CAI, Trinity, R1 rotors
Kenwood DNX9980HD - Audible Physics + US Amps being installed
wickedsr20 is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Car Audio / Multimedia / iCE
