2009 Nissan Altima Rear Speaker Install HELP - Nissan Forums : Nissan Forum
Old 01-06-2009, 05:03 PM
Arrow 2009 Nissan Altima Rear Speaker Install HELP
Hello All, Just need some help on how to install some rear 6'9 speakers on my 09 altima cause it dosent have any rear speakers. i seen one web site and it said that i would have to take the seat and most of the back apart.. my ? is ....... is there any way to do this (an easy way. reason the car is brand new and i don't want to take it apart. any help would be great, pictures would be great. any help will be awsome.
Old 01-06-2009, 06:24 PM
I actually just replaced all my speakers in my 08 a couple days ago with some new infinities. I will go take some pics on how to take the rear deck apart and post them if someone doesn't beat me to it.
EDIT: You don't have to completely take the back apart and you don't have to take the seat apart either although alot of people say you do.
Old 01-06-2009, 06:30 PM
kevinbp639's Avatar
Offset is everything
how much did the infinities cost you if you don't mind me asking. My friend just got a set in his truck and theyre awesome. Our local shop charged him 500 with install...
[Debadged][Tailight Overlays & GTR Headlight Overlays][Eibach Pro-kit][19" Speedy Octane Staggereds]
[Fujita WAI][Xentec 6000k HIDs][License Plate LEDS & Interior Swap][Autopia Fogs][M3 Lip Roof Spoiler][Sports Mesh Painted Grill and Logos]
-Dual 12" audiobahns | MTC: R. Valence Overlay | Magnaflow Tips
Old 01-06-2009, 06:37 PM
Ummm they were 400 when I bought them I believe, they are great speakers. Would recommend them to anyone. My sub is Infinity too.
Just took pics uploading them now.
Old 01-06-2009, 06:56 PM
Okay, this can get a little frustrating at certain parts BUT, it's not too difficult to do. The worst part is putting it back together:
First pull down the seat obviously and remove the 5 pegs that are holding this lip down. Once the pegs are out you just pull the lip down and it slides off easily
Here is a pic with the lip removed:
Once you get the lip off you need to take the side pillars off, to do this get a fine screwdriver and pop these little airbag emblems off
Under these covers is a bolt that you need a #10 socket wrench for if I remember correctly. Just take them out and then pop the pillar out. They come off with little resistance.
Next thing you can do is detach the rear deck and then peel the seat a little bit and you can lift the whole rear deck over the seat.
I don't have pics of my removing it but you get the idea and should be able to see what I'm talking about once you get there. Like I said it's not too difficult to do.
If you have problems getting the rear deck up you can go into the trunk and pinch the pegs and push them up so you can get the deck up.
(The white thing is the peg obviously)
Then once you get the deck up disconnect the brake light (you should be able to reach your arm under and unclip it, it's really easy to disconnect) and pull the deck down into your back seat.
From there you can do whatever to your speakers.
By the way, be careful when putting the deck back because the clips are delicate. I broke one on accident but it still fastens just fine.
Old 01-06-2009, 07:02 PM
There you have it
Also, the speakers are stuck down with adhesive so use a flathead screwdriver and just pry them up. I peeled the adhesive off the speakers and used them when putting my new speakers in so you don't get any rattling.
Good Luck!
Old 01-23-2010, 06:11 PM
Got it by now, thanks
Old 01-24-2010, 11:47 PM
I know this might be an old question, but I have a new 2010 2.5 Altima without rear speakers. I have already attached the radio, works great but now to tackle the rear deck.
Old 08-27-2010, 10:55 PM
NattyGirl's Avatar
Great write up on how to get to the rear speakers. I'm going to be installing some Infinite Kappa 693.9I speakers this weekend. Should be a breeze to do after looking at your instructions. Thanks!
2009 Altima 2.5S 4dr - Gray
Add-ons:
20" Rims
OEM Spoiler/Fogs
Depo Blk LED Tails
Tinted Windows
Bluetooth
Audiobahn Amp with 12" JL Audio W6v1 Sub hooked to stock radio in a Zenclosures sub box
Xentec HIDs 6000K - Headlights and Fogs
Takeda SRI Intake
Switchback LEDs 6K
LEDs in Interior, Cupholder, and Amb/Wht combo strip footwell lighting
BT's Hood/Trunk LED kits
http://www.cardomain.com/ride/3341067
Old 08-29-2010, 11:53 PM
I have Rainbow SL-165 coaxials for sale. they are 6.5", but they are already mounted on adapters, ready to be installed. They are in perfect condition.
Old 09-01-2010, 12:34 AM
this write up helped me a lot last saturday...I can't believe i was able to remove the deck and deadening under the deck, but i end up bending 2 clips on the deck, cos they're 4 of them. the rattling is so bad that i was afraid that the 3rd brake light housing will break my rear windshield. so now i'll have to take it apart again to put 2 new clips... can i buy these clips at autozone/pep boys or advance? or it has to be from the dealership?
Thanks...
Old 09-01-2010, 01:33 AM
Vital's Avatar
iTrader: 10 reviews
^^^ why was there a need for u to mess with your polks??
Old 09-01-2010, 01:43 AM
I did it cos, the deck was rattling so much, so i decided to put some deadening mat underneath the deck and also put some 3m double sided tape around the speaker mount and now the rattle is worse.
Old 09-02-2010, 05:54 AM
jimnolimit's Avatar
2010 2.5s Sedan
maybe something else is rattling, like the trunk spring bars
MY AUTO BLOG (COMPLETE WITH INSTALLS).
http://jimsautoeverything.blogspot.com/
Old 09-02-2010, 10:01 AM
I already took care of that with some padding.
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Car Audio / Multimedia / iCE
