I need a highs and mids amp and this is what i narrowed it down to for the $$ not going any higher than $100. I will pushing 4-6" subs and 4 tweets. If i can get at least 10 people to chime in which they would choose I will pick that amp and buy today. I am leaning more toward the RF because I had 2 punch 45 and a punch 60 back in the day and never had one single issue. BUTT! RE audio is "US AMPS" and you already know from back in the day there was no better.
CEA-2006 Compliant: CEA-2006 Guidelines <-----------
Number of Channels: 4
Rated Power
(RMS Continuous Power): 50 Watts x 4 @ 4-Ohm
75 Watts x 4 @ 2-Ohm
150 Watts x 2 @ 4-Ohm Bridged
Total Power
(Sum of Rated Power): 300 Watts RMS
Dynamic Power
(PVC/PowerCube® Measurement): 76 Watts x 4 @ 4-Ohms 0° Res
100 Watts x 4 @ 2-Ohms 0° Res
Bridgeable: Yes
Efficiency (average): 69% @ 4-Ohm
Crossover Controls: Front Channels
High-Pass/Low-Pass (HP/LP): 50-250Hz @ 12dB/octave Butterworth
Rear Channels
Tone Controls: Front Channels
Punch Bass: 0dB/+6dB/+12dB @ 45Hz
Rear Channels
Function works when crossover in (LP) position
DTX 750.4 (4CH / Class-AB)
Class AB, 4-Channel Full Range, MOSFET Power Amplifier
SKU #: DTX 750.4
Class: AB
Channel: 4 CH
Dynamic Power: 750 W
RMS Power (4Ω@14.4V): 60 W x 4
RMS Power (2Ω@14.4V): 80 W x 4
RMS Bridged Power (4Ω): 160 W x 2
THD: <0.02 %
SN Ration: 100 dB
Frequency Response: 10 Hz ~ 50 KHz
Crossover Frequency(Low Pass): 50 ~ 250 Hz
Crossover Frequency(High Pass): 50 ~ 250 Hz
Damping Factor: 180
Bass Boost Control: 0 ~ 12 dB
Input Sensitivity: 0.2 ~ 6 V
Heatsink Size(WxLxH) [inches]: 8.66 x 13.43 x 1.97
Heatsink Size(WxLxH) [mm] : 219.96 x 341.12 x 50.04
Fuse Rating: 40 A x 1
Rated Power
Total Power
Dynamic Power
Bridgeable: Yes
Rear Channels
Rear Channels
SKU #: DTX 750.4
Class: AB
Channel: 4 CH
THD: <0.02 %
SN Ration: 100 dB
Damping Factor: 180
