Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > ECM / ECU Tuning
Old 05-03-2007, 07:49 AM
How to tune my Altima and check/clear codes
I'm trying to figure out a way to check and clear CEL codes as well as tune my car a bit(it is running quite rich). I drive a 1999 Altima GXE so I was hoping that I could find a Consult cable to plug into my car's OBD2 port into my laptop and from there, check/clear codes and slightly tune the AF ratio to lean it out a bit(but still keep it safely tuned).
Does anyone know of a good cable for our cars? Also, what sort of program would I need on my laptop to do this?
Thanks.
-'99 5-speed Altima
Performance Mods: Hotshot CAI; Stillen 4-1 Header; OBX Catback Exhaust - Hiroshima Style; Vibrant Front Strut Tower Bar; S.T. Rear Anti-Sway Bar; Taz's Motor Mount Inserts
Audio Mods: Pioneer Head Unit; 4x60 watt Infinity 6200i 2-ways; Infinity Kappa Perfect 12.1 sub w/ Kenwood Amp
-1990 300ZX 2+2
Mods: Intake, headers, lightweight flywheel, RPS sport clutch, anti-sway bars, short shifter
Old 05-03-2007, 06:40 PM
Dark's Avatar
shift_Echo :)
you cant tune a stock ecu like that. you can however get a consult cable and check out most of the stuff going on in your car. if your car is running rich, the ecu is not your problem, these cars do run slightly rich higher up, but not thatttt rich. as far as i know the only way for you to get your ecu tuned, is JWT or if you wanted to go more extreme, AEM EMS. as of right now, theres not any way for us to tune obdII ecus (altho it should be possible... idk)
1994 Altima GXE - Auto
Sold 9-15-07
2003 Toyota Echo 2dr - Auto
Stock as stock can get
43.5mpg average
Old 05-04-2007, 05:54 PM
So no one has figured out a way to tune it using a Consult cable and a datalog program on a laptop? There must be a way to tune it considering it is OBD2.
Old 11-08-2008, 06:39 PM
Altima_Junkie's Avatar
97.5 Altima SE 5-Spd
I'm interesting in knowing that as well. I doubt we can do much at as as far as tuning on a stock ecu but being able to hook up my laptop to my ecu for diagnostics would be nice.
edit: ouch, sorry didn't realize I was bumping a year and a half old thread....
|60mm autoTB|OBX TB Spacer|K&N WAI|10.2mm plug wires|
Originally Posted by eclypse
i see. so you bore the headers, and increase compression through the cams?
quit typing, start hitting the search button. honestly, it works. but hey what do i know, ill be out in the garage boring the headers on my Nova..
Old 11-09-2008, 11:33 PM
The Don.
ALL OBD2 ECUs can be hooked up to a laptop to run diagnostics and do log recording, monitoring, etc. The OBD2 adapter that I have and would recommend is the ElmScan 5 USB (ScanTool.net - Products). Team that up with DigiMoto (Digimoto OBDII Vehicle Diagnostic Software) or something similar and you have some serious power in your hands.
You won't be able to program the ECU for tuning purposes. But you'll have a universal OBD2 scanner with lots of functionality.
ITEMS FOR SALE
Old 11-11-2008, 05:28 PM
Thanks for the links J. So If i want a tunable ecu i have to go with a jwt or similar then?
Old 11-12-2008, 03:19 AM
The Don.
Yes, you'll have to go with something that is fully programmable.
Old 11-12-2008, 04:22 AM
jayjaya29's Avatar
Rockin it!
What an SAFC2 should work and probably be the most economical if paired with a wideband O2 sensor and dyno time?
Click to see more!
2000 Nissan Altima GXE
-Eccho's TB Spacer
-Injen WAI
-Vibrant FSTB
-UR Pulley
-Custom 2.25" Catback
-ST Rear Sway Bar
-Liquid Ink A-Arm Brace
-Hotshot Headers
-Spec-V Rims
Old 06-08-2009, 01:04 PM
One option to the Consult-III is Augoenginuity. Go to autoenginuity.com and look through their stuff. The basic/generic package is $250 ($210 per ebay) and for an additional $100, you can purchase a Nissan-extended package that you can alter ignition timing, reset AFR, perform the idle-relearn, etc. There are all kinds of Nissan-specific tests you can perform on actuators. I think it has all the body and chassis failure codes. Seems to be a very solid little gadget. I think I'm definitely going to get one.
Not as extensive as Consult-III, but then again, nothing will be other than the CIII.
Consult III can do the job but for ~ 6000.00 US $.
