Nissan Datascan Map Trace Addresses - Nissan Forums : Nissan Forum
post #1 of 6 Old 01-25-2008, 08:07 PM Thread Starter
The Don.
Quoted: 5 Post(s)
Nissan Datascan Map Trace Addresses - '93/'94 Altima
Here is a list of the memory address locations for the Map Trace function in NDS. This is for the '93 and '94 Altimas (U13 KA24DE 93-94).
Primary Fuel Map
RPM MSB Address: 3475
RPM LSB Address: 3474
TP Address: 31B1
Map Address: 8100
TP Scale Address: 80F0
RPM Scale Address: 80E0
Primary Timing Map
TP Address: 31B1
Map Address: 8D00
TP Scale Address: 8490
RPM Scale Address: 8480
Secondary Timing Map
TP Address: 31B1
Map Address: 8800
Once you've filled in the required addresses for the Map Tracing Data, click the OK button and map tracing will start.
Enjoy.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
Last edited by jserrano; 01-26-2010 at 10:18 PM. Reason: Incorrect secondary address. Fixed links
jserrano is offline
post #2 of 6 Old 03-06-2008, 10:07 PM Thread Starter
The Don.
Quoted: 5 Post(s)
Nissan Datascan Map Trace Addresses - '96 Altima
Here is a list of the memory address locations for the Map Trace function in NDS. This is for the '96 Altima (U13 KA24DE 96). Others years could also apply but this has yet to be confirmed.
Primary Fuel Map
RPM MSB Address: 3473
RPM LSB Address: 3472
TP Address: 31B1
Map Address: E100
TP Scale Address: E0F0
RPM Scale Address: E0E0
Primary Timing Map
TP Address: 31B1
Map Address: ED00
TP Scale Address: E490
RPM Scale Address: E480
TP Address: 31B1
Map Address: E800
ITEMS FOR SALE
Last edited by jserrano; 10-19-2009 at 03:02 PM. Reason: Incorrect secondary address.
jserrano is offline
post #3 of 6 Old 03-14-2008, 12:43 AM
DIY'er
Quoted: 4 Post(s)
iTrader: 3 reviews
so these are settings for the tunerpro application???
drunkmunky is offline
post #4 of 6 Old 03-14-2008, 02:46 PM Thread Starter
The Don.
Quoted: 5 Post(s)
No, the values refers to a function called Map Trace in the Nissan Datascan (Nissan Data Scan ver. 1.5) application. In actuality, any application that performs map tracing can use those values.
This is the basis of how it works,
- The ECU reads the engine rpm via the distributor camshaft sensor. It stores this value in RAM locations 3472 and 3473.
- The ECU takes the MAF air coming in, calculates an engine load (TP) value, and stores this value in RAM locations 31B1.
- The ECU then looks up a map table stored in ROM. For example, the fuel map or ignition map table.
- It locates the row in this ROM table where the value equals the rpm value in 3472 and 3473.
- It locates the column across this ROM table to locate the previously calculated TP value in 31B1.
- The point of intersection between the TP and RPM will contain a value to use for the fuel injection; and even for the ignition timing.
- If the values for the rpm and TP does not fall squarely within the map ROM cell, then the ECU will use an interpolation routine to calculate a value that is the closest value possible.
The art of ECU tuning takes these stored ROM values inside the ECU and optimizes them for a particular engine. The default values stored in there were a trade-off for the engine requirements in terms of performance, fuel economy, and emissions.
ITEMS FOR SALE
jserrano is offline
post #5 of 6 Old 03-16-2008, 11:42 PM
DIY'er
Quoted: 4 Post(s)
iTrader: 3 reviews
ok so thats great. I wonder if this can be applicable to a jwt tuned oem ecu...
so this is a monitory map, our tunning would still have to be based off of other parameters?
post #6 of 6 Old 03-17-2008, 05:04 AM Thread Starter
The Don.
Quoted: 5 Post(s)
This will apply to all ECUs. And yes, this is valuable to monitor so that you will know where to make adjustments for fuel or timing.
ITEMS FOR SALE
jserrano is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > ECM / ECU Tuning
