Fuel Injector Problem 93 Altima
Hello....I need some good advice...my altima started running on 3 cylinders ,first i pulled each plug wire and number 2 was dead,went on and replaced plugs which looked fine pretty clean not any fouled out.So i listened to each injector and number 2 was weak,got an ohm meter and checked injectors out it registered 1,the rest was 11.4 or close...I think i also put the ohm meter in the wiring harness just on number 2 ....so i figured it had to be injector so i replaced it and now its very very hard to start you have to crank it forever and it will eventually fire up sometimes ,but want idle ,when you rev it up white smoke comes out smells like oil,it did not do that before new injector,so i checked the oil and it now has gas in in the oil.took plugs out and they are all fouled with gas.....could it be a new bad injector or checking the wiring harness on number 2 with ohm meter mess up the ecm or what i need to change oil but dont want to fill it back up with gas.....why are all the plugs fouled now...I need some help on what to do next....Help Me..Thanks Ken Is one injector staying open or all of the injectors stayin open???:
Reason: changed title
