how to test fuel pressure regulator? - Nissan Forums : Nissan Forum
Old 11-03-2003, 06:24 PM
PHASE 2 las vegas CC
Unhappy how to test fuel pressure regulator?
does anybody know how to test the stock FPR ? and if the stock FPR is mess up can I get a after market one to replace it?
thanks for the help guys...
Ray
Old 11-03-2003, 07:51 PM
SHAWN's Avatar
Import Tech.
You will need a fuel pressure gauge , at idle it should read around 35 lbs, remove the little vacuum hose and it should read around 45 lbs , if you notice gas in the vacuum hose at all , it is bad , and you may want to use a vacuum gauge to make sure it doesnt bleed down , also you can shut it off and make sure the pressure doesnt bleed off , it should be above 20 lbs after an hour of sitting ....if that tests good its ok ... Nismo has a nice adjustable pressure regulator avaliable for the KA's !!
SHAWN
Ger-Brock & Co. Portland OR.
'99 G20t Driver
'09 Sentra FE+ Wifes
'98 Sentra SE Time Attack
'06 Pathfinder SE Family Cruiser
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
Old 11-04-2003, 07:03 PM
the nimso is for 240sx I know that there are the same motor would it work on the altima?
Old 11-05-2003, 01:33 PM
Shadetree Mechanic
Yes.
IBI Wide body and Greddy SP1 catback FS
1993 Altima SR20DET Many mods.
2001 Maxima SE 20th Anniv./Auto
2004 Ford F150 Lariat SCAB Flowmaster/BIG BFG's
Old 11-05-2003, 07:51 PM
cool, thanks
Old 11-05-2003, 08:35 PM
weapon r has one , and its on ebay right now!
Old 11-05-2003, 10:33 PM
does the weapon r replaces the fatory FPR?
hey I seen one for a 93-97 weapon R FPR kit will It work on my 98 altima?
