motorvac? terraclean? - Nissan Forums : Nissan Forum
post #1 of 6 Old 03-16-2004, 02:35 AM Thread Starter
so,
my engine isn't running so hot as it used to....go figure
i keep seeing ads and signs for 'motorvac' and 'terraclean' fuel services. they are supposed to clean out the fuel system and injectors and such from deposits. sounds logical.....so i inquire, and lo-and-behold, they 'recommend' it....
has anyone out there had these services?
any reviews? bits of wisom?
cheers
Bn
bignasty is offline
post #2 of 6 Old 03-16-2004, 04:45 AM
Breu Meister
look for BG services in your area.
R.I.P. 2000 altima SE
Hello...
2003 Majestic Blue 6 speed maxima
Decoy is offline
post #3 of 6 Old 03-16-2004, 03:37 PM
It's Paid For.
SuperAlty's Avatar
I went to the Nissan dealer yesterday and had they Nissan Engine Fog service preformed. Took about 1 1/2 hours and it cleaned out lots and lots of carb. Car feels much better, idles smoother, and the power seems (butt dyno) smoother. Its been about 50 miles and the CEL for EGR has not come back on yet (knock on wood). Service was $139.95.
Originally Posted by hotlicia
..... i hate women that drive, they fukin suck at it
SuperAlty is offline
post #4 of 6 Old 04-02-2004, 06:03 AM
Tommy T.'s Avatar
I just learned about this service myself through a forum for my other car. I've got no experience with it myself but am in awe based on what I've read. Supposedly, Pat Goss from Motorweek has featured it on his show a couple of times and recommends periodic treatment every 35K or so. For what it's worth, here's a link to that thread, LOTS of posts with about 2 years worth of testimonials.
http://impalassforum.com/noncgi/ulti...;f=33;t=002148
Sounds too good to be true, huh? I'm gonna do some more reading up on it, was hoping to find more here. Unless I find a lot of negatives, I think I'm gonna take the plunge and give it a try on my 94 GXE with 96,000 miles on it, assuming I can find a shop nearby with the equipment.
Oh yeah, the thread refers specifically to the Motorvac Carbonclean system. Looks like cost runs anywhere from $75 to $200 depending on how much solution they run through your system. Other recommendations from the thread:
- make sure they use the proper solution, normally labelled either "Motorvac" or "Carbonclean" or some reference to "Parker" (the manufacturer).
- baby your car after the treatment, 1 or 2 days, because there is still some residual solution at work.
Here's another good link:
http://www.theautochannel.com/conten.../motorvac.html
Like I said, I've got absolutely no personal experience with the system, just repeating a common theme I stumbled across. And as that last link states, the procedure will "restore performance, restore smoothness, and restore efficiency".
Good luck, I'm curious to hear what kind of results you get regardless of the method used.
-- Tommy T.
My other rides . . .
2005 Dodge Magnum RT . . . 340 HP / 390 lb-ft
1995 Chevrolet Impala SS . . . 260 HP / 330 lb-ft
P-3 Orion . . . 4600 SHP x 4 engines
Tommy T. is offline
post #5 of 6 Old 04-02-2004, 03:52 PM
good article maybe I will give it a try in the next month.
Stillen header/2.25 custom cat back/Magnaflow Exhaust
Hot shots CAI
JET ECU Reprogram
NGK Wires/ V-Power
MSD Igniton/ Blaster 2 Coil
H&R springs & Toks/FSTB/RSB
Grounding
SWA pully
PR mounts
slotted, cross drilled rotors
Chris rusden is offline
post #6 of 6 Old 04-03-2004, 12:19 AM
Tommy T.'s Avatar
To echo Decoy's post, check out this thread. More good info:
http://www.altimas.net/forum/showthr...injector+clean
All about the BG system. About $100. Good results.
Tommy T. is offline
