2000 Altima and synthetic oil - Nissan Forums : Nissan Forum
post #1 of 17 Old 05-02-2004, 06:03 PM Thread Starter
Hi
Has anyone experienced seals leaks due to using synthetic oil in their 2000 Altima?
Thanks
Mike
Nissan fan: 82 280ZX and 00 Altima SE
Mike R is offline
post #2 of 17 Old 05-02-2004, 09:51 PM
Been using mobil1 syn 5w-30 since i bought my 2000 new...no problems at all....
sialtima is offline
post #3 of 17 Old 05-02-2004, 10:46 PM
hard on equipment
I've been using Mobil1 10w-30 since the car had about 25k on it, and it's great. No leaks experienced whatsoever.
This has been discussed about 300 million times - synthetic does not cause leaks, it's actually good for seals and such, but any worn seals that you may have had before you put the synthetic in are just more likely to show with the synthetic.
Godzildo is offline
post #4 of 17 Old 05-03-2004, 04:35 PM
Altimaboy
SexyGXE's Avatar
i switched to synthetic last oil change and drove across country and back 2 weeks later and I don't have a leak.
The thief comes only to steal and kill and destroy; I have come that they may have life, and have it to the full.
John 10:10
SexyGXE is offline
post #5 of 17 Old 05-03-2004, 07:17 PM
SHIFT_continuum
asuFoxtrot's Avatar
I have 114000 on my car, just switched to Mobil One, no problems so far. Hope it stays that way
|| JB District | 99 Performance | HP Autoworks ||
asuFoxtrot is offline
post #6 of 17 Old 05-04-2004, 12:42 AM
Car n00b
yeah, what happens if your car has had dino in it for a long time (like 10 yrs) and you switch to synth? i know the dino dries up the seals and can cause cracks, but the sludge covers them up and keeps it from leaking. upon the switch to synth, it cleans out the pipes and might expose the cracks and dried out seals (which it should re-moisten the seals after a while i think).
but what if the seals start leaking after having all the grime cleaned out? would they need to be replaced? and would that cost very much or be hard to do?
talz13 is offline
post #7 of 17 Old 05-04-2004, 12:47 AM
Ry
Quoted: 3 Post(s)
No problems here.
Former Moderator
2000 Altima
2008 Altima Coupe
2014 Altima
Ry is offline
post #8 of 17 Old 05-04-2004, 02:45 AM
What about tranny oil? What viscosity and type is needed for the 2001 manual? I've run synthetic in every vehicle I've had(all nissans, 90 maxima, 94 sentra se-r, 2000 frontier) in diff, trans and engine. No problems, in fact it probably saved my engine in a lot of cases. Sold all at high mileage without a problem.
nismoman42 is offline
post #9 of 17 Old 05-04-2004, 02:45 AM
What about tranny oil? What viscosity and type is needed for the 2001 manual? I've run synthetic in every vehicle I've had(all nissans, 90 maxima, 94 sentra se-r, 2000 frontier) in diff, trans and engine. No problems, in fact it probably saved my engine in a lot of cases. Sold all at high mileage without a problem. With the engine, just use a 0 weight flushing oil first and run it through the engine for 30-60 minutes at idle.
post #10 of 17 Old 05-04-2004, 02:45 AM
post #11 of 17 Old 05-10-2004, 02:45 AM
Car n00b
anybody to comment on the switch?
how about you, asufoxtrot? any leaks?
talz13 is offline
post #12 of 17 Old 05-10-2004, 03:23 AM
BLEUFIEND
ferrari550mr's Avatar
no probs here with a 2k alty that i switched over at 62000 using Mobil 1 syn
2k Altima GXE,manualhttp://www.altimas.net/registry/vehicles.php?vehicleid=2896
ferrari550mr is offline
post #13 of 17 Old 05-10-2004, 05:31 AM
I keep em comin back.....
BLACK SE's Avatar
Quoted: 1 Post(s)
Been using Mobil 1 since day 1. No problems whatsoever, but Amsoil is catching my attention quickly
BLACK SE is offline
post #14 of 17 Old 05-10-2004, 09:00 AM
SHIFT_continuum
asuFoxtrot's Avatar
nope, its been a couple of hundred miles, have no leaks whatsoever, my power steering fluid pipe is leaking now though . but thats another issue
post #15 of 17 Old 05-11-2004, 02:00 PM
Car n00b
maybe i'll think about switching... this was the only part i was wondering about after i read an article about synth. i'd be running it in a 94 gle w/ 49k
talz13 is offline
