Old 07-16-2004, 07:01 AM
Hotshot Install
So Im finally installing the new CAI tomorrow but I was wondering if theres anything I should look out for or be aware of when installing this. Also, all i have to go by is the SWA written instructions(no pics) so if theres anything besides that I should know plese fill me in.
By the way its a 98 if that matters
Old 07-16-2004, 07:16 AM
I AM LEGEND
What CAI do you have,and a search will work wonders..?
Old 07-16-2004, 07:19 AM
Michael4613's Avatar
http://www.nissantalk.com/forum/show...t=cold+install
Check out this thread. It helped me out a lot even w/ my Injen intake installation.
Old 07-16-2004, 07:22 AM
SHIFT_Wounded
yea, u might need 2 buy hoses that actually fit....and if u have abs u might be ****ed, and have a metal cuttin tool(like a dremmel) 2 make the hole bigger
01 sil nissan alty auto: Not Sold! but maybe repoed soon
will someday own a b14 5spd! can u say sr20det? or maybe vet? possibilities, possiblilities... (the mini alty)
my lost baby 04 sil nissan sentra spec v! 6spd close ratio+hlsd=realllllllllly fun time, gone, but surely not forgotten
Old 07-16-2004, 06:33 PM
The Don.
Ditto, I used RejectBaby's instructions as well. He did an excellent job on his writeup. Here are a few of my tips,
1. Use a portable drill and circular hole saw to widen the hole by the battery. Make sure that all drill batteries are fully charged.
2. Free up the tight fit of the negative ground cable by moving it higher up on the available hole left over from the airbox removal.
3. Use a plastic retainer clip to plug the hole on the intake for the Intake Air Temperature sensor if you don't have this sensor on your car.
4. The filter can be installed from underneath the car without having to pull back on the entire splash shield.
5. Use petroleum jelly to help position rubber-to-metal parts together.
6. Do an ECU reset after completing the work.
ITEMS FOR SALE
Old 07-16-2004, 07:51 PM
abdiel's Avatar
I have ABS so I guess I'm ****ed. I tried installing my hotshot
intake in my 95 alty last week but the small tube can't fit because of the ABS, I heard that some people here modified their intake to fit but none of those people have reply to my thread.
Any ideas for me, what can I do to install the CAI.
Thanks,
Abdiel
AbDiEL
Old 07-16-2004, 08:09 PM
SHIFT_Wounded
i think theres a faq for the abs cai install, ill try 2 look for that for ya
Old 07-28-2004, 05:43 PM
abdiel's Avatar
I sent an e-mail directly to Hotshot and asked then if the
CAI can be installed in an Altima that has ABS, and this the reply
from the Hotshot staff:
Hi
Yes it sure can, I've done it myself. If he is having problems, it's because he has one of the tubes installed backwards. The nipples point down.
Thanks
John
Hotshot
I was thinking that the nipples should point up. Anybody has the
nipples pointing down?
Thanks.
Old 07-28-2004, 06:27 PM
bangmatic's Avatar
You're my boy Blue!
its pretty much a straight forward install
they told me the same thing when i emailed them. tried it both ways and had no luck at all. the bomz/ebay midpipe fit perfectly though
Items For Sale!!
1st Gen VIS OEM Carbon Fiber Hood
1st Gen Aftermarket Parts
Old 07-28-2004, 07:48 PM
PrOuD To Be HaWaIiAn
look at the title of the thread, it'll do wonders....j/k
Former 1998 Altima Owner
Present 2000 Toyota 4Runner Owner
Old 07-28-2004, 10:59 PM
abdiel's Avatar
So did u just got a new one from ebay? What about the midpipe
that comes from hotshot. Does anybody with this CAI has the nipples pointing down?
Old 07-29-2004, 05:28 AM
Biggest 2nd gen wheel gap
wait...it comes with a splash shield?
