Valve Clearance - Nissan Forums : Nissan Forum
post #1 of 14 Old 12-07-2004, 11:01 PM Thread Starter
Valve Clearance
I have a question for you guys, my car started to make this bussing noise kinda like when the Alternator is about to go out, but its not my Alternator, the noise is coming from under the valve cover, I checked for the Timing Chain guide and it doesnt have one, I have a 98 Altima GXE, I was just wondering if anybody has had this problem before, I did an Oil Change and it still hasnt gone away, I was reading through the Haynes manual and it says that part of a tune-up is to check and adjust the valve clearance if the valve train is making noise, my questioon to you guys is what kinda noise does the valve train make? By the way I have 137,000 miles on my Alty.
dj trace is offline
post #2 of 14 Old 12-08-2004, 07:07 AM
The Dude
ULTIMATUC's Avatar
sounds like your cam lobe to lifter clearances are sloppy. have a tech check it for you.
ULTIMATUC is offline
post #3 of 14 Old 12-08-2004, 05:06 PM
Import Tech.
SHAWN's Avatar
Valve adjustment to loose will cause a clicky noise .... Yea, have a shop check it out ...
SHAWN
Auto Shop Northwest O.C. OR
'09 Sentra FE+ Driver
'14 Crosstrek Wifes
'98 Sentra SE Time Attack
'09 Titan CC LB SE
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #4 of 14 Old 12-08-2004, 09:18 PM
Breu Meister
Quoted: 1 Post(s)
I knew I needed valves adjusted... just hit 60k miles and for some time now the engine made a noise which def seemed to be comming from under the valve cover.
R.I.P. 2000 altima SE
Hello...
2003 Majestic Blue 6 speed maxima
Decoy is offline
post #5 of 14 Old 12-08-2004, 09:19 PM
Breu Meister
Quoted: 1 Post(s)
p.s. since we are on topic of valve adjustment where could I go to get it done and roughly what prices am I looking at here?
Hello...
Decoy is offline
post #6 of 14 Old 12-09-2004, 04:26 PM
Import Virgin
My car is making the same ticking noise too ... also wondering about the cost of getting this fixed.
Would they adjust it if i took it into the dealership for a tune up??
serag is offline
post #7 of 14 Old 12-09-2004, 08:57 PM
Import Tech.
SHAWN's Avatar
Most likely a dealer would not .... I have done a couple here at the shop , to check it it is an Hour $75 .... But if any need adjusting its about $250 + shims , which are about $10 ea. ....
SHAWN
'14 Crosstrek Wifes
'09 Titan CC LB SE
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #8 of 14 Old 12-09-2004, 09:11 PM
Import Virgin
Thanks Shawn...one last question...would adjusting them be covered under warrenty??
serag is offline
post #9 of 14 Old 12-09-2004, 09:47 PM
Breu Meister
Quoted: 1 Post(s)
shawn you think I should just save up money for an engine rebuild/build?
Hello...
Decoy is offline
post #10 of 14 Old 12-10-2004, 12:46 AM
Import Tech.
SHAWN's Avatar
Not covered under warrantee unless it got noisy in 3 years or 36,000 miles , if its over the 60K , thats just maintenance ....
Rebuild ?? All Depends on what you want to do with it ..... If its running ok now , a little noise will not hurt anything , just kinda anoying and will affect power a little ....
SHAWN
'14 Crosstrek Wifes
'09 Titan CC LB SE
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #11 of 14 Old 12-10-2004, 03:05 AM
RIP 6/24/07
I plan on checking and probably adjusting (seen as it has 194k on it) the valve clearance. I have the tools and the know how to do it. I'm just wondering where would I go to get the shims? The dealership right? or is there someplace else I can get them?
Originally Posted by SLOW KA_
haha..I really get a kick out of people trying to turn the KA into some kind of high revving monster,like power is going to mysteriously appear because you add short runners on the mani,high compression pistons yadda yadda yadda...like these things havent been discussed to no end.
Everyone who is serious about having a "fast" KA is either FI or N20 equipped.SHAWN is the exception to that though.
Go forced induction or squeeze,or go home.
Eccho is offline
post #12 of 14 Old 12-10-2004, 05:47 PM
Breu Meister
Quoted: 1 Post(s)
when i mean rebuild/build... I want to do up my engine like spring/summertime like what you did to your old 93.. I want to make my 2000 a beast! def gonna swap to manual, lightened flywheel, lightened pulley, CAI, hotshot header, custom exhaust, drop, lightweight rims, and then bring to a machinist with probably 5 grand of engine parts... then the AEM EMS and tuning. hopefully if everthing comes out I am looking at 230 whp
Hello...
Decoy is offline
post #13 of 14 Old 12-10-2004, 07:17 PM
Import Tech.
SHAWN's Avatar
I have looked everywhere, Dealer only ....
SHAWN
'14 Crosstrek Wifes
'09 Titan CC LB SE
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #14 of 14 Old 12-18-2004, 10:18 PM
RIP 6/24/07
Okay thats what I thought.
Eccho is offline
