O2 sensor extension wire??? - Nissan Forums : Nissan Forum
post #1 of 14 Old 03-02-2005, 01:31 PM Thread Starter
01 SE 5mt
AltiChrisSE01's Avatar
I would like to know if anyone here has found and/or purchased an O2 extension cable for the Altima (98-01)
this is for relocating the O2 behind the cat after you install the header.
I keep running a code and my tech friend thinks it is because i spliced the wired on the O2 side between the O2 and connector that itis trowing a bad signal???
anyother advise/options woul dbe appreciated
thanks
we rock the latest flip flops to avoid the wooden splinters --- C.O.M.A. ny CANDIRIA 718
AltiChrisSE01 is offline
post #2 of 14 Old 03-03-2005, 04:31 AM
I AM LEGEND
No extenders that I know of.
Do you know what code is popping up?
SLOW KA_ is offline
post #3 of 14 Old 03-03-2005, 09:53 AM Thread Starter
01 SE 5mt
catalyst failure code
basically itis saying the cat is bad (brand new) so i figure it is the second o2
post #4 of 14 Old 03-03-2005, 01:21 PM
Pulski's Avatar
I'm throwing a code for the rear o2 as well. I'm replacing both and probably rewiring the extension at the same time.
Gotta pass emissions this month.
2009 Subaru Impreza WRX 5-door -- 2004 Subaru Impreza WRX Wagon (Stage 2) GONE -- 1998 Subaru Legacy GT
Altima Parts. Buy them or die.
Pulski is offline
post #5 of 14 Old 03-03-2005, 07:50 PM Thread Starter
01 SE 5mt
^ as do I and thisis why I am doing this
post #6 of 14 Old 03-03-2005, 08:52 PM
Official Troll
No extension. Gotta cut, solder, and heat shrink it.
flarearrow is offline
post #7 of 14 Old 03-03-2005, 09:09 PM
Breu Meister
Quoted: 1 Post(s)
dude... go grab some wire the same gauge, get yourself a universal o2 sensor, splice the wires, solder them together, put the heat shrink around it and call it a day. come on now...
R.I.P. 2000 altima SE
Hello...
2003 Majestic Blue 6 speed maxima
Decoy is offline
post #8 of 14 Old 03-04-2005, 05:39 AM
Biggest 2nd gen wheel gap
just called my mechanic today about this(I recently got a heat temp sensor CEL on both O2 sensors...seems they both died, first rear then front.), he said extending the o2 sensor is just simple splice and crimp, thats it. I was riding on that for about 2 months before I got a CEL(o2 sensor just died). I dont know if it died because of the splice or because its the stock sensor (Im at 85k)- u decide.
98GXE
Heim Endlinks, ST RSB,
A-Arm Brace, FSTB, GC coilovers
KYB GR2's, 17" Custom Enkei RS6's
Greddy SP1, Hotshot Header
Hotshot CAI + JWT Pop
2k1 Blacked out Headlights
Slickdvl is offline
post #9 of 14 Old 03-04-2005, 11:25 AM Thread Starter
01 SE 5mt
i did that, but throwing a code again and my tech was thinking it was due to the splices, if i can find a wire harness side O2 connector and i have my own o2 connector side. I will make my own o2 sensor
you think i couldnt do this, hahahaha I laugh
just trying to make a preminent solution
post #10 of 14 Old 03-04-2005, 12:57 PM
Once again in a DSM!!
retired DSM'r's Avatar
Hey AltiChris, not to doubt your skills or anything man, but did you check that the wires match up, my friend did his own extension and was getting a cel, he bought everything that he can think of and in the end it was that he put the wires on the wrong spot.. LOL..
If not, i think it was Danny who did a write up on how to get rid of the CEL. check in the FAQ.
retired DSM'r is offline
post #11 of 14 Old 03-04-2005, 02:43 PM
Pulski's Avatar
Yeah, it was Danny "P0420 Fix" and it involved wiring in a resistor.
Pulski is offline
post #12 of 14 Old 03-04-2005, 04:48 PM Thread Starter
01 SE 5mt
yeah they are correct, i did one at a time - cut one, wire in the extension, cut the next...
I ran with no code for a few months but then it just began, i think i might need a new sensor also, If i buy a universal that has no end on it, ill extend the wires on that they put the end on the extension
but again, im just looking for a way to eliminate the splicing
post #13 of 14 Old 03-05-2005, 04:47 AM
Pulski's Avatar
Checked the codes today and mine is 0902, rear o2 heater not functioniing. I'm going to rewire the extension and replace the rear sensor to hopefully take care of it.
Pulski is offline
post #14 of 14 Old 03-05-2005, 08:17 AM
same here pulski....except im getting both front and rear...even tho i replaced the front one(so mechanic says it might be the fuse). And i have no idea which fuse it is...
98GXE
Slickdvl is offline
