what is a power transistor - Nissan Forums : Nissan Forum
post #1 of 13 Old 03-31-2005, 03:08 AM Thread Starter
93 GLSE Auto
hey guys i did what was said in the chilton to test a power transistor and it didnt read as it should... question is when i discoenct it it doesnt run at all but connected it runs what exactly does this piece do.. i have searched but no clear answers... i do have a ruf idle and wondering if this the cause i just want an underanding of that this is
Ace
2002 Maxima SE 6 Speed hlsd
1993 Altima SE Auto
realeztace is offline
post #2 of 13 Old 03-31-2005, 03:53 AM
A Transistor is a switch, maybe theyre referring to the main relay?
BTW I have an auto transmission with 55k if you are interested..
Danny7633 is offline
post #3 of 13 Old 03-31-2005, 03:55 AM Thread Starter
93 GLSE Auto
how much what year and is it lsd and will my car funstion with a malfuntioning main relay
Ace
1993 Altima SE Auto
post #4 of 13 Old 03-31-2005, 03:57 AM
99 no lsd, Im in massachusetts. No your car will not function if the main relay is not working. Intermittent problems are something to consider too though, I dont know your symptoms or the issue you are having so I cant offer any more advice.
post #5 of 13 Old 03-31-2005, 03:59 AM Thread Starter
93 GLSE Auto
thanks anyway so whats ur asking price
Ace
1993 Altima SE Auto
post #6 of 13 Old 03-31-2005, 04:27 AM
Quoted: 7 Post(s)
The power transistor is the light grey (on my '93 IIRC) plug that's mounted I believe on the brass looking metal plate that is just past the MAF....(can't picture it very clearly right now)....
Jeremy
niceguy is offline
post #7 of 13 Old 03-31-2005, 11:02 AM Thread Starter
93 GLSE Auto
i know where it is and wha it is but what exactly does it do
Ace
1993 Altima SE Auto
post #8 of 13 Old 03-31-2005, 05:40 PM
The Don.
Quoted: 5 Post(s)
The power transistor is basically a fast switching transistor that makes and breaks powers to the primary side of the ignition coil. Without it you cannot get the ignition coil to provide high voltage to the secondary winding which happens to feed the distributor. In our cars, the ECU turns the power transistor ON and OFF and that in turn provides ground (or not) to the primary side of the ignition coil.
Before the dawn of high tech electronics in the newer cars, a car used a breaker point inside the distributor which opened and closed with a cam inside the distributor. Mechanics would adjust the point gap and set dwell to provide for proper primary coil functionality. The power transistor replaced both the point and cam and eliminated one mechanical headache.
If the engine runs whatsoever then it is working.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #9 of 13 Old 03-31-2005, 08:46 PM Thread Starter
93 GLSE Auto
so then why when dpomg the test according to the chilton manual mine should be faulty and yes i know how 2 use a multi meter i went to electronics school
Ace
1993 Altima SE Auto
post #10 of 13 Old 03-31-2005, 09:34 PM
The Don.
Quoted: 5 Post(s)
Double check the test with this http://www.autozone.com/servlet/UiBr...3d801b5c90.jsp
ITEMS FOR SALE
jserrano is offline
post #11 of 13 Old 03-31-2005, 09:59 PM Thread Starter
93 GLSE Auto
same test i did and i failed it
Ace
1993 Altima SE Auto
post #12 of 13 Old 03-31-2005, 10:07 PM
Import Tech.
SHAWN's Avatar
i have never seen a good test for the transistors ....always test bad ...
SHAWN
Auto Shop Northwest O.C. OR
'09 Sentra FE+ Driver
'14 Crosstrek Wifes
'98 Sentra SE Time Attack
'09 Titan CC LB SE
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #13 of 13 Old 03-31-2005, 10:16 PM Thread Starter
93 GLSE Auto
so then should i replace it?
Ace
1993 Altima SE Auto
