p0400 (EGR Malfunction) replace??? HELP - Nissan Forums : Nissan Forum
post #1 of 27 Old 04-13-2005, 11:16 PM Thread Starter
01 SE 5mt
AltiChrisSE01's Avatar
so i threw a P0400 sode (Exhaust Gas Recirculation Flow Malfunction)
should I just replace the EGR?
we rock the latest flip flops to avoid the wooden splinters --- C.O.M.A. ny CANDIRIA 718
AltiChrisSE01 is offline
post #2 of 27 Old 04-14-2005, 04:19 PM
The Don.
Quoted: 5 Post(s)
Very rarely does the EGR valve dies altogether. Instead, the EGR stem gets badly clogged up with carbon and stays wide open and when you decelerate to a stop sign you will get an extremely bad idle. Sometimes the EGR stem manages to close but leaves a small crack opened because of the carbon deposits and that causes erractic idle. In other words, the idles is good a few seconds and then it occasionally drops and feels like the engine has misfired. Either way, you can use something like carb cleaner and a toothbrush to clean it out.
There are other areas that gets clogged up as well. It has been discussed before.
I recently fixed an EGR problem in my car and here is the link,
http://www.nissanclub.com/forums/sho...d.php?t=187463
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #3 of 27 Old 04-14-2005, 09:43 PM Thread Starter
01 SE 5mt
yes, i was searching a lot today and founf abuch of things that say clean it out before you replace, ill do that
also my idle has been ruff at stop signs after the car is warm
thanks
post #4 of 27 Old 04-15-2005, 05:41 AM
junkyalt's Avatar
i took mine off 2 years ago and blocked it off.I just dont like the idea of extra carbon build up in my intake and all.Havent had a bit of problems, well with that system anyways.Strange "ignition signal" code that not a single person knows about.
junkyalt is offline
post #5 of 27 Old 04-15-2005, 09:43 AM Thread Starter
01 SE 5mt
yeah but I cant get an inspection with an engine code in NY anymore
post #6 of 27 Old 04-19-2005, 12:34 PM Thread Starter
01 SE 5mt
found a clog in the oraphis (sp?) that comes off the egr manifold to the egr sensor, this adds back pressure to the canister but it was clogged.
ill see if the cel hits again
post #7 of 27 Old 06-01-2005, 09:51 PM
c'old man winter
orifice :> i have to check my egr / evap stuff out too, i just dont know where to begin, as i have all the symptoms
Brian Passarelli is offline
post #8 of 27 Old 09-09-2005, 05:45 AM
Lookin' for a hooptie
omegax's Avatar
I know this is an old post, but great approach to this problem. While everyone was pointing me towards my ignition ( where i was also recieving a"mystery" code for... but i could not find anything wrong with my distributor or any other part.
The problems you describe sound very familiar. How would i go about removing the EGR completely???
94 Altima = TOTALED!!!
My replacement car...---->
1988 Chevy Celebrity 2.8L CL
/w EuroSport package...... = DEAD
Now....
07 OBP WRX
omegax is offline
post #9 of 27 Old 09-09-2005, 07:15 AM
because hondas suck!!
3391's Avatar
remove that POS from the engine alltogether.....contact ACEALTIMA he is making block off plates for that.
check out my site!
3391 is offline
post #10 of 27 Old 09-09-2005, 09:32 AM Thread Starter
01 SE 5mt
i fixed it a while back thanks though
post #11 of 27 Old 09-09-2005, 01:41 PM
will ace's blockoff system cause a CEL?
1997.5 Altima GXE Ltd.
My first car, owned for 9 years and sold 09/2012
My FOR SALE thread
http://www.nissanclub.com/forums/par...rbo-parts.html
zadeluca is offline
post #12 of 27 Old 09-09-2005, 02:01 PM
The Don.
Quoted: 5 Post(s)
He should tell us if it does. Seems to me like it would because the EGR temperature sensor wouldn't get exhaust gas hitting on it and that would alert the ECU to a bad EGR system.
ITEMS FOR SALE
jserrano is offline
post #13 of 27 Old 09-09-2005, 03:13 PM
you get that blockoff plate and kiss your gas milage goodbye
rush0 is offline
post #14 of 27 Old 09-09-2005, 06:25 PM
3391's Avatar
actually i know someone else who has done it and his not suffering with gas milage. remember the EGR system is putting hot exhaust gas back into the intake manifold.
check out my site!
3391 is offline
post #15 of 27 Old 09-09-2005, 07:07 PM
^thats what i was thinking. if anything i would think that removing the EGR would increase mpg, but soon enough ace will chime in on this thread...
My FOR SALE thread
zadeluca is offline
