Check engine light ON; Code P0705 - HELP, PLEASE - Nissan Forums : Nissan Forum
post #1 of 9 Old 03-23-2006, 01:38 AM Thread Starter
Nissan Altima 97 Check engine lights ON ; Error code: P0705 ( Transmission Range Sensor Circuit Malfunction); Changed inhibitor yesterday by a trasmission expert but the light comes back on after two days, CANNOT pass the state inspection. Urgent; the sticker will expire MAR-31st, Please help!
What can I do? Thank you so much for your help. Any information will be appreciated!!!!!!!
Chen
emi_chen is offline
post #2 of 9 Old 03-23-2006, 04:37 AM
I am not sure what your problem is with the sensor, but if you just needed the light to go off so that you can pass inspection....you could turn your ecu into test mode so that no codes stay and the light won't be on. I believe that is 1/2 way around on the knob, so the dial is in the middle.
themancalledchris is offline
post #3 of 9 Old 03-23-2006, 01:41 PM
Nissan Hack
He can't do this if he lives in a state that does OBDII emissions testing. Where I live (Pittsburgh) there is no tailpipe test anymore. The emissions tester plugs directly into the OBDII port on the car and scans the logs for trouble codes, pending trouble codes, and monitors. He will fail because not enough of his OBDII monitors will be set if he resets his ECU.
Manual Transmission Wisdom - Knowing how to drive a manual is not the same as driving one well.
XS6DFG0_Jay is offline
post #4 of 9 Old 03-24-2006, 07:28 PM
naijaboy's Avatar
Quoted: 1 Post(s)
Test it with another ECU.
naijaboy is offline
post #5 of 9 Old 03-24-2006, 07:55 PM
Nissan Hack
Yeah right.............you find a shop that will do that.
Any garage or mechanic in PA that gets caught doing that is in deep $hit.
post #6 of 9 Old 03-24-2006, 08:09 PM Thread Starter
Thank you all
Thank you all for your messages.
I had another auto shop checked my car today. And they said if over the weekend the light does not come back and they will do the state inspection again for my car. Well, hopefully by then, my car can pass the inspection.
The big headache is if the light comes back on after few drive cycles, I have to send it to the Nissan dealer and it may cost $$$ to fix the same problem. What if the same problem comes back again later on, say three months? I have to face it every year near the inspection time. Sigh!
I can ONLY HOPE the BEST.
emi_chen is offline
post #7 of 9 Old 03-24-2006, 09:00 PM
The Don.
Quoted: 5 Post(s)
The problem should be somewhere in the Neutral Position switch, Inhibitor switch, shifter, or harness.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #8 of 9 Old 03-24-2006, 09:08 PM
Nissan Hack
Isn't state inspection fun? It's the best time of the year.
Look on the bright side, you have an OBDII(2) compliant car..........
wait until you see what they have in store for you when OBDIII(3) comes out.
Seriously, good luck.........if it came back after replacing the inhibitor switch, it will probably come back again.
This is an automatic, correct? Did the transmission guy say anything about the PNP?
post #9 of 9 Old 04-03-2006, 06:25 AM
AlÚcia, meet nissanclub
nycxkilla's Avatar
Stupid TRS Circuit Malfunction code. What a headache
Hahahahah. i looked all over the internet for that code to see what the hell it meant and what it was.
It's a code that checks if your gear is in the neutral position.
My car is getting that code too because i put in an Autostarter/alarm system.
In order to prevent my car flying ahead (because the clutch has to be tripped), a wire is spliced into the TRS to check if the gearbox is in neutral.
Solution:
My friend/mechanic was saying to put in a diode into the spliced wire so the electric current doesn't go back into the TRS circuit.
But in your case, just make sure the wire is in good condition and that it's making a full circuit.
http://www.240sx.org/faq/articles/95_ecu_pinout.htm (check this sight out for the wire for the Neutral Position Switch)
1995 Nissan Altima GXE 5-speed
Her name: AlÚscia
Did:
-AsianWolf autostarter/alarm
-Pioneer DEH-P770mp Head unit
-NGK Iridium spark plugs
To do:
-TWM Short-shifter
-HIDs
-Get rid of that engine light [DONE]
-NGK spark plug wires
nycxkilla is offline
