  #31 (permalink)
Old 07-24-2007, 12:48 AM
Iceman00's Avatar
King of The Powerslide
Altima Alumni
KA24DE-K
"The K is for kaizen, which translates to "improvement".
NEW UPGRADE GUIDE. CHECK BEFORE YOU ASK QUESTIONS:
http://www.nissanclub.com/forums/eng...ml#post3100261
Unofficial Dyno thread
http://www.nissanclub.com/forums/gen...898-prove.html
Z3: 210whp/217wtq
  #32 (permalink)
Old 07-24-2007, 06:56 PM
vehemence's Avatar
dthmtlsk8r
94 Altima GLE/AT,Greddy SP1 Cat Back,Hi Flow Cat,
OBX 4-2-1 Header,OBX TB Spacer w/bypass,
Bomz Short Ram Intake w/JWT Filter,UR Pulley,
Eprom ECU Chip,JWT Cams,SWA Ground Wires,
NGK Wires/Plugs,FTSB/RSWB, Liquid Ink A-Arm Brace,
Racingline F/R Endlinks,Racingline MMI,
Sprint 2' Drop Springs,Sprint Struts
Slotted/Drilled Rotors,Ceramic Pads,
Enki 17' Polished Rims,Hancook Tires,
Upper/Lower Billet Grill,Depo Clear Bumper/Headlights
Euro Clear Corner Lenses,95-97 Stock No Amber Tails
  #33 (permalink)
Old 07-25-2007, 02:34 AM
Dark's Avatar
shift_Echo :)
wanna buy my spare ecu dude?
1994 Altima GXE - Auto
Sold 9-15-07
2003 Toyota Echo 2dr - Auto
Stock as stock can get
43.5mpg average
  #34 (permalink)
Old 07-25-2007, 05:00 AM
Iceman00's Avatar
He has dibs on mine.
  #35 (permalink)
Old 07-26-2007, 03:44 AM
Dark's Avatar
shift_Echo :)
oh lol my bad
  #36 (permalink)
Old 07-26-2007, 05:58 AM
Iceman00's Avatar
No problem. I'm actually basicly giving it to him. All for the sake of research.
  #37 (permalink)
Old 08-28-2007, 06:14 PM
The Don.
I'm bringing this thread back because I have some information for you guys related to this stuff.
First off vehemence, have you gotten a chance to look into the E-Mance stuff?
I got a pair of correct 512K daughterboards from Calum for the '94 Altima. And they work great!!! His daughterboard can actually be switched between 32K and 64K ROM mode. That means you can program them to be used in a 64K or 32K ECU. He will prepare your ECU with the required daughterboard for about $103 when you ship him the ECU. I believe it also covers the type of tune you want but I am not sure so you'll have to ask him. I asked him to program stock ROM binaries for me since I want to start learning this stuff a little at a time. Oh, BTW, he mentioned that E-Mance is a basic older version of his daughterboard design but that it should work fine.
Here are a few things that I know DOES work.
ECUs for automatic transmissions and manual transmissions have different binary codes but...
- A '93 Altima ECU for automatic transmission (that's correct, '93) will directly plug in and run on a '94 Altima with manual transmission without a single hitch.
- Conversely, a '94 Altima M/T ECU programmed with a '93 Altima A/T binary will also directly plug in and run on a '94 Altima M/T.
- A '94 Altima ECU with automatic transmission will directly plug in and run on a '94 Altima manual transmission.
- A '94 Altima M/T ECU programmed with a '94 Altima A/T binary will also directly plug in and run on a '94 Altima M/T.
- All '94 Altima ECUs for XE, GXE, SE, or GLE has the same binary codes and are therefore interchangeable.
- A S13 ECU with manual transmission can directly plug in and run on a '94 Altima M/T.
I haven't actually started any real ECU tuning per se since I have just been running some street tests to see what works and doesn't work on my Altima. But I'll put all my info over on the ECU tuning forum from time-to-time.
Hopefully, some of us can move the DIY ECU tuning for the Altima along since it has been seriously lacking around here.
ITEMS FOR SALE
  #38 (permalink)
Old 08-28-2007, 08:47 PM
RIP 6/24/07
hmm might have to check this out for my 94 sentra... although its pretty hard to do something like this when i know that the jwt tune for the 1.6 sentras is pretty damn good..... and would actually be perfect for the basic bolt ons plus jwt cams i'm planning.... its weird i was never really sold on the NA jwt tune for the altimas... but its different on my sentra for some reason..
Originally Posted by SLOW KA_
haha..I really get a kick out of people trying to turn the KA into some kind of high revving monster,like power is going to mysteriously appear because you add short runners on the mani,high compression pistons yadda yadda yadda...like these things havent been discussed to no end.
Everyone who is serious about having a "fast" KA is either FI or N20 equipped.SHAWN is the exception to that though.
Go forced induction or squeeze,or go home.
