Old 07-17-2007, 11:10 PM
vehemence's Avatar
dthmtlsk8r
Is this legit?
eBay Motors: NISSAN 93 94 ECU ECM FAST CHIP ALTIMA QUEST (item 200077961919 end time Aug-08-07 12:19:49 PDT)
Sorry if this is another bunk ebay add but I read thru this one and this chip plugs into the actual ecu rather than maf sensor. Its not a resistor. Claims to peform the same functions as JWT/jet upgrade. New rev limit, top speed, fuel and map timming.... Its price is cheap and thats what scares me please check it out and give an honest opinion.
94 Altima GLE/AT,Greddy SP1 Cat Back,Hi Flow Cat,
OBX 4-2-1 Header,OBX TB Spacer w/bypass,
Bomz Short Ram Intake w/JWT Filter,UR Pulley,
Eprom ECU Chip,JWT Cams,SWA Ground Wires,
NGK Wires/Plugs,FTSB/RSWB, Liquid Ink A-Arm Brace,
Racingline F/R Endlinks,Racingline MMI,
Sprint 2' Drop Springs,Sprint Struts
Slotted/Drilled Rotors,Ceramic Pads,
Enki 17' Polished Rims,Hancook Tires,
Upper/Lower Billet Grill,Depo Clear Bumper/Headlights
Euro Clear Corner Lenses,95-97 Stock No Amber Tails
Old 07-18-2007, 12:05 AM
Iceman00's Avatar
King of The Powerslide
Check Zilvia for info on Emace chips. That Dyno is PDM's dyno. An ECU upgrade alone shouldn't make you lose low end power...
Altima Alumni
KA24DE-K
"The K is for kaizen, which translates to "improvement".
NEW UPGRADE GUIDE. CHECK BEFORE YOU ASK QUESTIONS:
http://www.nissanclub.com/forums/eng...ml#post3100261
Unofficial Dyno thread
http://www.nissanclub.com/forums/gen...898-prove.html
Z3: 210whp/217wtq
Old 07-18-2007, 12:21 AM
Iceman00's Avatar
BTW, Check your Email.
Old 07-18-2007, 01:54 AM
AquaX's Avatar
I wish someone from here would go for it. I really want too see if this tune is any good. If it's good it would save me tons even after the cost of converting my car to obd1 its still cheaper then jwt.
Old 07-18-2007, 09:21 AM
vehemence's Avatar
dthmtlsk8r
I think I might try it out. Hell its 40$ and they make it sound like its pretty easy to install and take out if needed. (like for smog testing) I dont know gotta sleep on it. I wish there were install instructions online just so I could see what im getting into before I commit to buying it
Old 07-18-2007, 11:41 AM
He makes it sound so easy. I see an issue with that. I'd rather have more control over the process and the power to adjust it.
Old 07-18-2007, 01:08 PM
The Don.
Something doesn't sound right to me...
First off, the Altima ECU has a soldered-in ROM chip which is of the large-scale PLCC packaging type. The picture on their ad is of a simple memory chip.
Take a very good look inside my ECU and tell me where that chip will install into,
http://home.comcast.net/~serrano.j/a...aECUside11.jpg
By the way, the Altima ECU ROM is called a Versatile ROM and it is the big one to the topmost right side of the picture, it has a sticky label on it. The Versatile ROM has a lot more internals than that of a simple memory chip.
The only way I could see that chip getting installed is by putting it into a daughterboard. And if that is the case, the installation require electronics soldering skills, not easy for the average Joe Blow.
Here is a picture directly from their own e-Bay site,
http://i11.ebayimg.com/07/i/000/88/09/9350_1.JPG
Get them to send you the exact installation instructions for you to review. Better yet, have them give you three eBay users that has installed it on their Altima (we can then send them direct eBay messages to verify legitimacy.) Post that information here. And we can tell you in a heartbeat if this is legit enough to work. If they balk at sending you the installation instructions or eBay users, then buyer beware.
UPDATE:
Here is yet another link from them for your enjoyment,
http://eformance.info/ecu/
ITEMS FOR SALE
Old 07-18-2007, 02:10 PM
98gle#2's Avatar
white on rice
Dont tell me you guys are falling for this too....
White 1998 Altima GLE
Injen wai
OBX header & cat-back
Some subs and amps
Black '01 headlights
Powerslots & hawks
Spec-V Rims powdercoated black
Tokico struts
Suspension Techniques springs
Originally Posted by Red Lion
I'm glad SOMEBODY finally said it. And of course it'd be YOU
Originally Posted by Eclypse
Considering you dont have a lift and I'm picturing this thing falling on your face, you may want to clearly understand what is involved here.
Old 07-18-2007, 05:44 PM
Iceman00's Avatar
I'll have to check Zilvia again. They had a thread on this, and I'll see how it turned out.
Old 07-18-2007, 08:09 PM
NissanaRacer3000's Avatar
Evil Member
well, i emailed the seller and they just responded
"we're working on 98+ now, hopefully it will be done in a few months"
Old 07-18-2007, 09:02 PM
Pulski's Avatar
^^ People have been saying that for years about the 98+ ECU.
Listen to the people in this thread... this chip is not going to work properly.
2009 Subaru Impreza WRX 5-door -- 2004 Subaru Impreza WRX Wagon (Stage 2) GONE -- 1998 Subaru Legacy GT
Altima Parts. Buy them or die.
Old 07-19-2007, 08:26 AM
vehemence's Avatar
dthmtlsk8r
So with the links jserrano posted it looks like his ecu needs a motherboard. It would still work. I know I would need help. If the ecu matches there first example then we are in buisness and it shouldnt be hard. Ill take it to a tv repair store and have them take out the old chip and put in a sproket so I can take it on and off when i desire. Dosent seen that hard just need a good solderer.
Old 07-19-2007, 04:10 PM
94 GXE Auto
This topic was discussed a year ago.
I emailed this guy last year and he told me that I'd need a daughter board to make it work with Altima. I'm not sure but it will cost you around $50 or more.
Yeah, and he also suggests to get it soldered by someone in electronics repair shop ($10).
I don't see the reason why it shouldn't work but I didn't want to be the guinea pig.
Old 07-20-2007, 03:19 AM
vehemence's Avatar
dthmtlsk8r
Well I checked ebay responses and most were good. I need another ECU to work with just incase things go to hell.
Old 07-22-2007, 01:42 AM
Dark's Avatar
shift_Echo :)
it seems you need a daughterboard... if you check the ECU forums a month or two ago i was in contact with a guy about these chips for our cars. they are supposedly good chips (altho i havent looked at zilvia in a while). he said that he would do everything for my ecu for $100 plus me shipping my ecu out to him. it seems pretty legit to me, altho you need some soldering skills and a daughterboard for this to work i bet.
my guess is that the pic he posted was just for looksies... he seemed pretty credible when i talked to him a few months ago
1994 Altima GXE - Auto
Sold 9-15-07
2003 Toyota Echo 2dr - Auto
Stock as stock can get
43.5mpg average
