Firing Order Performance V4 - Nissan Forums : Nissan Forum
post #1 of 11 Old 07-18-2007, 10:53 AM Thread Starter
Okay, well I had a ?.
2001 Altima GXE
the correct firing order is 1-3-4-2
˅< 31
>^ 42
going in this order ** this is the round thing **
21
34
what would happen if I changed it to 4-2-1-3?
˅< 24
>^ 13
I understand that many developers just use the common firing order that everyone else uses for that cylinder number.
I also understand that it will always repeat like this
134213421342
421342134213
So it is still going to go in the right order overall, but what I am thinking about will start it at 4*otherside* instead of the number 1 cylinder.
I like to think outside of the box. So, if all replies could think like me and think of the best or other unknown methods of reaching the same goals.. well, that would be great.
ps, this site is great! 2001 Nissan Firing Orders
Engine Firing Orders
runcoolisback is offline
post #2 of 11 Old 07-18-2007, 01:11 PM
///M Time!
jayjaya29's Avatar
Quoted: 1 Post(s)
iTrader: 3 reviews
If you changed the firing order, the spark plugs would spark during the exhaust/intake phase of the engine cycle. It wouldn't work.
Howstuffworks "Internal Combustion"
Click to see more!
2000 Nissan Altima GXE
-Eccho's TB Spacer
-Hotshot CAI
-Vibrant FSTB
-UR Pulley
-ST Rear Sway Bar
-Liquid Ink A-Arm Brace
-Hotshot Headers
-Spec-V Rims
-Rear Disc Brakes
jayjaya29 is offline
post #3 of 11 Old 07-18-2007, 01:41 PM
white on rice
98gle#2's Avatar
˅< 24
>^ 13
Your next thread title would be "HELP, my car wont run!"
White 1998 Altima GLE
Injen wai
OBX header & cat-back
Some subs and amps
Black '01 headlights
Powerslots & hawks
Spec-V Rims powdercoated black
Tokico struts
S/T springs and rsb
FSTB
Originally Posted by Red Lion
I'm glad SOMEBODY finally said it. And of course it'd be YOU
Originally Posted by Eclypse
Considering you dont have a lift and I'm picturing this thing falling on your face, you may want to clearly understand what is involved here.
98gle#2 is offline
post #4 of 11 Old 07-18-2007, 01:50 PM
You'd lose.
CvlEngAltima's Avatar
I'd imagine you'd have some serious timing issues.
The timing on specific engines can be changed, but not just arbitrarily.
1999 Firebird Formula Trans Am WS.9, M6, Blue-Green Chameleon
1987 GMC Jimmy, TBI350/TH350, 10b, 6" lift, 35" tires.
Neither quite stock.
http://community.webshots.com/user/OutlawLS1
Originally Posted by Pulski
Cvl... this may never happen again, so take note of it. Thank you.
CvlEngAltima is offline
post #5 of 11 Old 07-18-2007, 02:22 PM Thread Starter
Do you guys even have any idea of what you're talking about? THEY ARE STILL IN THE SAME ORDER!
you can't freaking put 1 and 2 together also 3 and 4. 98gle READ THE ENTIRE post before having a smartass reply! wow.
For jayjaya29, I'm not changing the ORDER, it is still going in order. just starting on the second set first.
Anyway, to someone that at least has an idea of what he's talking about. CvlEngAltima, do you know what the delay between firings are? In the firing order 134213421342 most of the force is left in cylinder 3. In the firing order 421342134213, most of the force would be left in cylinder 2. Are you saying there is a pause between 2 to 1 in the normal timing. last time I checked, once started it doesn't have a difference in delay between any of the firings once started.
post #6 of 11 Old 07-18-2007, 03:46 PM
white on rice
98gle#2's Avatar
i have read your entire post, and posted a smart reply because you dont have any idea how things work.
if you think you are genious, go try it...
because when you stark with a spark to cylinder #2, it will be in its compression stroke, causing a huge knock and kill your engine.
i understand at what your trying to say, but everything would have to be re-worked and #2 would have to be at TDC. before timing. While this is thinking outside the box (and i give credit for that), it is silly.
P.S. the great site you found was posted by me about 4 months ago.
Injen wai
Some subs and amps
Powerslots & hawks
Tokico struts
S/T springs and rsb
FSTB
98gle#2 is offline
post #7 of 11 Old 07-18-2007, 03:46 PM
The Don.
Quoted: 5 Post(s)
Keep this in mind,
The camshaft position sensor (CMP) has a marker to the #1 cylinder. The ECU knows that, and together with other markers, i.e. CMP slits, can calculate the exact TDC position for the remaining cylinders. Let us say, we are on #1 cylinder; the ECU sees that and will fire, in tandem, the #1 fuel injector and the ignition - and hopefully the ignition will occur on the #1 cylinder.
So, with that in mind, and if you want to get away with it, you would also have to re-route the fuel injectors to coincide with the ignition firing order.
I am still trying to understand what is the 'gain' here. Either way, how about giving it a try and telling us how the engine performs?
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #8 of 11 Old 07-18-2007, 03:56 PM
white on rice
98gle#2's Avatar
Originally Posted by jserrano View Post
Keep this in mind,
This is true with the injectors, but i still would not reccomend trying it.
Injen wai
Some subs and amps
Powerslots & hawks
Tokico struts
S/T springs and rsb
FSTB
98gle#2 is offline
post #9 of 11 Old 07-18-2007, 05:05 PM
I keep em comin back.....
BLACK SE's Avatar
Quoted: 1 Post(s)
agree with jserrano, what is it that you are trying to accomplish? I cannot see any gain in doing this......if you do try, you are going to spend countless hours trying to figure out the ECU, because it will be completely confused with what you did to the firing order....
BLACK SE is offline
post #10 of 11 Old 07-18-2007, 07:29 PM
Import Tech.
SHAWN's Avatar
Yea, the firring order is 1342 , but that doesnt mean it starts at 1 every time ... it starts wherever the engine shuts off at ....
So it can be 1342 or 3421 or 4213 or 2134 .......it all depends on where the engine is at when you shut it off ...
Oh and its not a V4 ..its a I4 ...
SHAWN
Auto Shop Northwest O.C. OR
'09 Sentra FE+ Driver
'14 Crosstrek Wifes
'98 Sentra SE Time Attack
'09 Titan CC LB SE
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #11 of 11 Old 07-18-2007, 07:55 PM
Pulski's Avatar
That's like saying a clock will ALWAYS start at 12... The engine goes around and around in that order. It doesn't start/stop at a specific spot.
2009 Subaru Impreza WRX 5-door -- 2004 Subaru Impreza WRX Wagon (Stage 2) GONE -- 1998 Subaru Legacy GT
Altima Parts. Buy them or die.
Pulski is offline
