Old 04-02-2008, 03:03 AM
Rough idle when in drive only - SES light on
I have a 2000 Altima Automatic with 80k miles that is idling rough only in drive. The SES light is on.
I tried getting the error codes from the ECU, but I can't see that damn screw. Its like I have to put my head under the brake pedal to see it.
A friend suggested that its a vacuum leak. I did some one vacuum related things today. Changed spark plugs, check the cap and rotor, both excellent. Ran it without the air filter, no change.
Any suggestions?
Old 04-02-2008, 02:10 PM
The Don.
Have someone like AutoZone read the codes for free. If you get a P0303 or P0304, or related code, then get ready to open your pockets for replacing an intake manifold gasket.
ITEMS FOR SALE
Old 04-02-2008, 10:17 PM
One code came back as P0325 knock sensor 1 circuit malfunction
The other was P0304 cylinder 4 misfire detected.
Old 04-03-2008, 03:48 AM
bingo! just like jserrano said, intake manifold gasket leak.
the knock sensor code is not a huge deal - but you might as well have it replaced while the intake manifold gasket is getting replaced. the whole jobs gonna gonna cost ya though...
1997.5 Altima GXE Ltd.: HS CAI and 4-2-1 Header, Magnaflow Cat, OBX Cat-Back, FSTB, Poly-filled mounts, Nology Hot Wires, AT Grounding Kit, ES CA and FSB Bushings, Racingline Endlinks (F&R)
Waiting to be Installed: Rear Disk Conversion, 5 speed swap
Near Future: ST RSB, Toks and H&R's
My turbo thread
http://www.nissanclub.com/forums/for...ka-t-club.html
