Good job....I also used Chinabean's BASIC tutorial and then realized that I was better off swapping everything over that I could (after a heavy degreasing). However, I did ask Asleep for pointers
Only problem I've had is that according to the crank pulley (left the 2000 pulley on and did you notice the timing index pointer is on one side of the cover instead of the center?) my timing marks are about 3 inches to the right of the pointer. Can't get them even close.
The cars runs very good and I also noticed better low end pull due to the cams. So far with about 70% city and 30% hwy mileage on my first full tank with the new engine, I'm getting about 28-29mpg
Only thing I can really guess is that somehow the crank pulley didn't get locked in properly by the 'notch key' and must have rotated a little clockwise while tightening w/the impact. All theory, and unless the crank seal goes bad soon, I'm leaving everything alone as long as it runs good...
Oh, congrats!
BTW, Asleep, not only did I do half of my swap in the dark, but with mosquitoes the size of dragonflies...Not sure how many pints of blood I lost....
