01 Altima - Help Changing the Fuel Filter 02 Sensor Thermostat Distributor - Nissan Forums : Nissan Forum
post #1 of 13 Old 02-24-2009, 03:27 PM Thread Starter
CarAudio & Elect. Pro
james33440's Avatar
I have a 2001 Nissan Altima SE with a Auto Tranny. It has around 98K miles or so.
The only thing I have noticed wrong is that the RPM's tend to be higher than normal when idling and in drive. It tends to take several mintues when going down the ride before the RPM's go down to where it normally is when in Overdrive.
I never have so I am going to go ahead and change the Spark Plugs & Wires, and the Distributor cap, and possibly the Fuel Filter and maybe even the pump.
I was thinking of changing the O2 sensor and maybe even the thermostat.
What do ya'll think?
Also, where is the Fuel Filter located on my '01 Altima?
Anything I should know prior to changing the Distributor? I am going to replace the Distributor, Cap, and Rotor package.
Oh, and is there anything I should know when changing the 02 Sensor and Thermostat? Where exactly are those located?
If anyone can take a picture and then use MS Paint or something to circle or show an arrow pin-pointing the location, I would be greatly appreciative.
Thanks.
2001 Altima SE w/ 18" chrome Arelli Jovan's
Alpine CDA-9855 (3Way Mode)
Kicker Resolution RS6 Components (Active Setup)
CDT Tweeter Image Enhancement Kit
3 Ascendant Audio Arsenal 12's (Sealed)
Kicker KX650.4
Kicker KX1200.1 @ 0.67-ohm
Stinger Wiring
My CarDomain Rides
james33440 is offline
post #2 of 13 Old 02-24-2009, 04:56 PM
///M Time!
jayjaya29's Avatar
Quoted: 1 Post(s)
iTrader: 3 reviews
Fuel filter located on firewall just above the throttle body...its a silver cylinder.
O2 sensor located right on the header, its the thing sticking out with wires from the header.
Would change the cap, rotor, spark plug wires and most importantly the spark plugs before replacing the distributor. Kinda excessive to replace the distributor if its not showing any signs of problems.
Thermostat again I would leave alone if the car heats up and stays in the correct temp range during normal use.
Click to see more!
2000 Nissan Altima GXE
-Eccho's TB Spacer
-Hotshot CAI
-Vibrant FSTB
-UR Pulley
-ST Rear Sway Bar
-Liquid Ink A-Arm Brace
-Hotshot Headers
-Spec-V Rims
-Rear Disc Brakes
jayjaya29 is offline
post #3 of 13 Old 02-24-2009, 05:18 PM Thread Starter
james33440's Avatar
Ok thanks.
I will probably just change the Spark Plugs and Wires along with the Fuel Filter and o2 Sensor.
I will hold off on the Fuel Pump and Thermostat.
Kicker KX650.4
Stinger Wiring
My CarDomain Rides
post #4 of 13 Old 02-24-2009, 05:59 PM
Rippen RJ
WarMachine's Avatar
iTrader: 4 reviews
Yeah I would change the wires and plugs with NGK. Change the distributor cap and rotor, you should see if oil is also contaminating the distributor. If you do pull out the full distributor, change the o-ring to the engine. Try cleaning your MAF sensor, it is located on your intake pipe. Use Contact cleaner or carb cleaner or maf cleaner.. I wouldn't change the fuel pump unless you are going turbo or no2 or if it is going out. If it isn't, don't touch it. Thermostat, if your engine is cooling fine and isn't overheating then it should be ok. o2 sensor, you can check with a volt meter to make sure it is running correctly. Same thing with the MAF sensor. Fuel filter is located in the engine bay, firewall in front of the driver side.
Honestly, the best thing you can do right now is go invest about $20 for a Haynes manual book and they will show you setup by setup, location, and how to's on these sort of things.
Mods
Bomz Sentra CAI
OBX 4-2-1 Header
Front Strut Bar
Custom Rear Strut Bar
Koyo Radiator
MSD Blaster Coil 2
Stuff For Sale...
Turbo Kit
It's not the quantity of your post, it's the quality of your post...
WarMachine is offline
post #5 of 13 Old 02-24-2009, 06:05 PM Thread Starter
james33440's Avatar
^ yeah, I have been using this....
Index of /FSM/Altima
Kicker KX650.4
Stinger Wiring
My CarDomain Rides
post #6 of 13 Old 02-24-2009, 11:37 PM
july notm winner!
blackalti's Avatar
buy the cap, rotor, plugs, wires (both ngk!!!!) fuel filter....all of that shouldn't take more then an 30 minutes to change...but itll cost you about $150 -\+ oh and if you still need some pictures let me know and ill get some up for you later tonight
i paint "fancy" valve cover's pm me for detail's
blackalti is offline
post #7 of 13 Old 02-25-2009, 12:16 AM
KA24DE > SR20DE
mad hatter's Avatar
I dunno about anybody else but my O2 sensor was a HUGE c.u.n.t. to get out when I tried using a crescent wrench. Go to your local parts store and you can buy an O2 sensor socket (Just a socket with a notch in it) and that will make your life infinitely easier.
2002 Subaru WRX Wagon: Rally Armor Mudflaps, TurboXS RFL turboback, Cobb AP (Stage 2), Prodrive GC-10 17x7.5
1993 Nissan Altima: KSport Kontrol Pro, I/H/E w/ cat delete, FSTB, ST sway bar, Racingline RS MMI and Endlinks, JWT ECU, 5Zigen Proracer ZR+520 17x9 +27 PARTING OUT
143whp & 146ft/lbs
mad hatter is offline
post #8 of 13 Old 02-26-2009, 01:50 AM Thread Starter
james33440's Avatar
I am going to hold off on the Distributor, Cap, and Rotor. I will do the Fuel Filter, Spark Plugs, and the wires.
Also, I am going to go with a BOMZ intake.
Kicker KX650.4
Stinger Wiring
My CarDomain Rides
post #9 of 13 Old 02-26-2009, 01:53 AM
july notm winner!
blackalti's Avatar
the cap and rotor ended up costing me like $20 at auto-zone...its worth it
post #10 of 13 Old 02-26-2009, 04:18 PM Thread Starter
james33440's Avatar
So, go ahead and change those and use the same distributor?
Kicker KX650.4
Stinger Wiring
My CarDomain Rides
post #11 of 13 Old 02-26-2009, 05:46 PM
Rippen RJ
WarMachine's Avatar
iTrader: 4 reviews
You should pull out your distributor too and change that o-ring that is connecting it to the engine block. But yeah I would change the cap and rotor on the same distributor.
Mods
Bomz Sentra CAI
OBX 4-2-1 Header
Front Strut Bar
Koyo Radiator
MSD Blaster Coil 2
Stuff For Sale...
Turbo Kit
post #12 of 13 Old 02-26-2009, 05:47 PM
KA24DE > SR20DE
mad hatter's Avatar
Ya. Changing the distributor at this point would be overkill.
143whp & 146ft/lbs
post #13 of 13 Old 02-27-2009, 12:16 AM
///M Time!
jayjaya29's Avatar
Quoted: 1 Post(s)
iTrader: 3 reviews
From what I remember, 2nd gens don't have the problem with the leaky distributor o-ring....
Click to see more!
-Eccho's TB Spacer
-Hotshot CAI
-Vibrant FSTB
-UR Pulley
-ST Rear Sway Bar
-Hotshot Headers
-Spec-V Rims
-Rear Disc Brakes
