Hasn't made any difference since I haven't gotten it tuned. So its sitting at 1 to 1. What the MAF puts out is what the ECU sees.
Installation was not too bad, just gotta be careful when wiring it up.
Don't got any pics of the install, its pretty straightforward though.
I paid $250 for mine used.
Oh and just for future use, here is the pinouts I used to wire it up. This is specific for 00 Altima:
Red wire- pin 56 or 61
red/white wire- pin 56 or 61
Green wire- pin 3
Gray wire- pin 23
Brown wire- 39, 43,106,112 or 118
Black wire- same as brown pinouts
cut wire pin 47
Yellow wire- pin 47 ecu side
White wire- pin 47 harness side
orange wire is illumination power- To illumination power, can connect to headlight switch, dashlights, head unit, etc.. (It's for dimming the SAFC when you turn on the lights. You do NOT need it. Basically your NEO will dimm when you turn on your lights... so you can see better at night and not get blinded by the bring neo.
Green wire- pin 3
Gray wire- pin 23
cut wire pin 47
but after you do get a tune..how much of a difference is their gonna be,, gimme a approxiamation, one of my frinds has it in his 06 altima said he agained about 25whp which sounds liek its worth it, how much can u mess around with it?? whats the most u can get out of it?
I'm expecting 15 to 20 WHEEL horsepower gain with cams and tune.
Tune alone can free up 10 HP to the wheels from what I've read on here.
These cars run pig rich up top, leaning it out will increase HP....and save gas.
