Old 07-04-2009, 12:54 AM
CAI for 95 altima
Where can I get a CAI for a 95 Altima ? I only see short RAMs everywhere...
Thanks.
Old 07-04-2009, 01:17 AM
01NismoAltima's Avatar
YOU cant get a CAI for your Altima.. But I can.
http://www.cardomain.com/ride/2960386
Engine: Hotshot CAI, Xcessive Intake Spacer, Apexi filter/charger, OBX 4-2-1, 2.5" SS Catback w/ Magnaflow muffler, UR pulley, Race MMI, Optima Red Top.
Suspension/Brakes: EBC Dimpled & Slotted rotors, EBC Green Stuff pads.
Wheels/Tires: Sportmax 039 (17lb), Goodyear GT 245/45/17.
Extras: Drop Resistor Mod
On Bedroom Floor: Obx rad hoses, Tokicos
Old 07-04-2009, 01:29 AM
Im listening...
Old 07-04-2009, 02:30 AM
They no longer make them... production for an cold air intake system stopped about 7yrs ago i think.. I happen to be lucky enough to own one of them..
So really, you are SOL...
BUT, if you are serious, you can use the brilliant idea that Warmachine came up with.. Just buy a 2002-2003 sentra CAI (NON SE-R)...
Hopefully you know that a CAI is not just a simple install. you will have to cut an existing hole larger for the pipe to fit through..
Old 07-04-2009, 04:52 AM
blackalti's Avatar
the black alti
cai's are gay.....enough said...
http://www.nissanclub.com/forums/nis...-vote-now.html
VOTE FOR ME FOR NISSAN OF THE MONTH!!
Old 07-04-2009, 07:51 AM
WarMachine's Avatar
Rippen RJ
Nahh I beg to differ. There are benefit from the CAI just like how there are benefits with a WAI. Either way, I believe both are better than stock. Just different power ranges.
Mods
Bomz Sentra CAI
OBX 4-2-1 Header
Front Strut Bar
Custom Rear Strut Bar
Koyo Radiator
MSD Blaster Coil 2
Stuff For Sale...
Nissan EGR Plug/Fitting
Turbo Kit
It's not the quantity of your post, it's the quality of your post...
Old 07-04-2009, 09:25 AM
something like this ?
2000-2004 NISSAN SENTRA COLD AIR INTAKE 2001 2002 2003:eBay Motors (item 190319207521 end time Jul-08-09 22:56:15 PDT)
cutting the hole wont be a problem ...
Old 07-04-2009, 04:24 PM
WarMachine's Avatar
Rippen RJ
I used one more like this, just remember your gonna need to slightly modify it so it fits. Just remember the link I used DOESN'T include the MAF adapter.
Old 07-04-2009, 04:34 PM
I already have a short ram installed, so I wonder if the long pipe will reach the hole just ok once attached to the MAF.
Old 07-04-2009, 07:48 PM
WarMachine's Avatar
Rippen RJ
It should but you might as well use the midpipe it comes with.
You can try and see if you can buy like a straight pipe and then buy a 90 degree bend to put it in the hole. Might be a cheaper route instead of buying a whole new kit.
Old 07-05-2009, 07:51 AM
95-99 maxima cold air intake will fit better then sentra.
Old 07-05-2009, 08:08 AM
WarMachine's Avatar
Rippen RJ
Haven't tried but from what I see from the pics of a Maxima intake it looks like it should work fine. Have pics installed assiN?
