if you mean rwd, your 2nd gen is a no-go. with a first gen altima (U13) i would either get the bluebird AWD motor then make it rwd from the awd tranny, or do it the hard way and find a junk S13, weld the H-brace crossmember for the rwd motor, pull out the alty gas tank for a trunk mounted fuel cell, install the rear wheel hubs, and find a way to mount the rear diff and driveshaft.
if you mean rear wheel 5 lug conversion, theres a thread on that, you get them from the old maximas.
