ok so i've had this issue for some time now and i cant seem to figure out why the hell my car slips when i hit 2nd gear but not off the start in 1st from a dig,i've tried stage2 240sx flywheel lightweight/stage3 same flywheel/now excedy oem same flywheel,yes it has been resuface whenever a new clutch was mated to it.this shit cost me a $120 tonight,he barely could keep his fender in front of me wit the clutch acting up,it cause me to tap sec once on top of the madness
How badly does it slip before it grabs? Do you have to let off the gas? Does it do it in any other gears? How long has it been doing it? When did it start?
Done: H&R/tok's, I/H/E w/ cat delete, FSTB, ST sway bar, Racingline RS MMI and Endlinks, JWT ECU, 15'' 240sx wheels
Originally Posted by allblackedout111
People will tell stories of the legendary white vq powered altima that races down the touge late at night when no one's around. All you can hear is the vq heel toe sound rolling through the mountains, but it's a ghost, no one has ever really seen it, only stories exist. But it's out there, oh it's out there.
AngryBot: Well when two admins fall deeply in love...they can't physically have children so they adopt one and that's how a moderator is made.
Pulski: Just because you have a less slow car than some here, doesn't make you any less of an idiot.
if you're 200% sure its not the clutch or flywheel, then blackedout is probably onto it. i'd look at the alignments of practically everything outside the transmission. you didnt forget to put that metal spacer/shield thing between the engine and tranny back on last time you had it apart did you?
My garage:
'01 Altima GXE-LE (fully built..not fully working) build thread here:http://www.nissanclub.com/forums/for...-go-again.html
'05 Acura TL-Navi (i/e, tint, sway bar, fancy brakes)
'72 Nova (dragster, 500+whp on bottles)
'69 Karmann Ghia (show car)
'73 Nova (show car, chromed out 383, 500+hp)
If he forgot the spacer, it would make it hard to disengage b/c the clutch assy would be closer to the flywheel. The more I think about it, you may have something wrong with the hydraulic system that's causing it to not engage the clutch fully.
One other thing to consider is a rear main seal leak. It would have to be pretty bad to contaminate a clutch so soon though...
9-10hrs work days has kept me away from you fans! seriously i think its my flywheel because its the only thing that has been in there with every clutch combo,someone said the the offset of a 240 flywheel is different,so that+it being aftermarket could be why after the break in-period the clutch begins to slip.
but if it was slipping I would suspect it would do it in every gear all the time.
Not only did you have the same flywheel during all clutch setups, but don't forget you had the same hydrolic system too. I'm still curious about how high the clutch engagement is on the pedal. If its near the top I have a theory about what could be happening.
