Old 11-07-2009, 01:25 AM
Problem with 97 altima!! Help me!
OK so I have a 97 altima with 232000 miles on it. It ran great all year until the weather started changing. In the morning if the weather is cold, it runs good for a minute or so and the idle rises and drops like crazy. It does it until it dies out and when I start it back it sputters and putts and blows out black and smells like old engine oil. On a warm it day it runs good, but after a few drives it acts up and dies out. Its been to the shop over 5 times. Its had the plugs replaced, new distributor with new cap and rotor,new knock and crank sensors and new pipe for the exhaust. The guys checked the MAF sensor, idle motor, fuel filter,fuel pressure and everything seems ok. I added fuel injector cleaner and gas treatment and it ran good for a while but then it started acting up again. And its getting worse everyday. Does anyone have a clue about what could be causing this? It's really frustrating!!!
Old 11-07-2009, 04:02 PM
98gle#2's Avatar
white on rice
does it act up and die at idle or while driving? Have you tested vacuum?
White 1998 Altima GLE
Injen wai
OBX header & cat-back
Some subs and amps
Black '01 headlights
Powerslots & hawks
Spec-V Rims powdercoated black
Tokico struts
Suspension Techniques springs
Originally Posted by Red Lion
I'm glad SOMEBODY finally said it. And of course it'd be YOU
Originally Posted by Eclypse
Considering you dont have a lift and I'm picturing this thing falling on your face, you may want to clearly understand what is involved here.
Old 11-07-2009, 05:34 PM
It acts up when at idle and while driving. I didn't test the vacuum cuz I don't know how. Last night my wife said it was acting up while parked on a hill and when she got on the flat road it stopped. It sometimes smells like gas too. Could it be the fuel pump?
Old 11-07-2009, 07:42 PM
WarMachine's Avatar
Rippen RJ
Hmmm it could be signs of the pump going but try ruling out the EGR first. Unplug the hose connected to the EGR from the intake manifold and try plugging it with a bolt or something. Does it run better, worse, or the same? If you have the Haynes manual book, it shows how to test a lot of the parts before you start replacing them. You can also check the fuel pump too.
Mods
Bomz Sentra CAI
OBX 4-2-1 Header
Front Strut Bar
Custom Rear Strut Bar
Koyo Radiator
MSD Blaster Coil 2
Stuff For Sale...
Nissan EGR Plug/Fitting
Turbo Kit
Old 11-07-2009, 11:41 PM
I checked the vacuum hoses and a hose on the egr is cracked. There is also a hissing sound coming from the back of the engine by the intake manifold.
Old 11-08-2009, 12:40 AM
WarMachine's Avatar
Rippen RJ
I would try to change that hose first since it's a lot easier. But that hissing sound is making me think your intake manifold gasket is toast. Try spraying carb cleaner around the intake manifold where it meets up to the block. Does the idle raise to a better more sturdy idle or so?
Either way, change the hose that is cracked first. And no check engine lights on?
Old 11-08-2009, 02:46 AM
yeah I'm gonna change that hose first and see what happens. There's no check engine light on. It went off after I had those sensors changed. The intake manifold gasket is about a year old. It was changed when the mechanic put an new headgasket.
Old 11-08-2009, 09:43 PM
rtkskater44's Avatar
ewwfffff...another altima
wen you changed the sensors... did u clear the codes or did the CEL just go off... if it just went off you may have sum stored codes... i would check it with obd2 scanner and gather wut codes (if any) and then clear them
Blackalti:
bow your head...
dear heavenly father......please be with raziel....for he needs your help.....he does not understand english....nor can he type it.....please be with him so that he may one day FULLY understand car's....because lord as of now...hes lost.....all these things i ask in jesus' name...
amen!
amen..
Old 11-09-2009, 01:22 AM
The mechanic changed the sensors so I don't know if he cleared the codes. I'm assuming he did though but I'll ask him and hear what he says. I want to buy one of those scanners. Are any cheap ones that I can buy?
Old 11-09-2009, 04:20 PM
The Don.
I also have to agree that this sounds like some type of intake leak. You should be able to confirm that with a vacuum gauge if its a really strong leak.
ITEMS FOR SALE
Old 11-09-2009, 11:16 PM
OK so I just changed that cracked EGR vacuum hose and it's still acting up. I started it and it ran good for a minute but the it started idling funny again. So I gave it a rev and it died right out. I cranked it a few times and when I got it started I rev it and heard a popping sound coming from under the car. The tailpipe is also really black especially on the outer tip. I just called my mechanic and he said the already tested it to see if there is an intake leak and it doesn't have one. So he's coming to get it tomorrow and hopefully he finds what it is. I'm still open for opinions so feel free to give me advice you have. Thanks.
Old 11-10-2009, 12:07 AM
Cc
could be a clogged catalytic converter. if the back cat is bad so is the front. if the front is bad, the back may be bad. if thats what it is.
Old 11-10-2009, 06:02 AM
yeah i'm starting to think so too.I just had a piece of the pipe in front changed because there was a leak. But yeah maybe that's why its making that popping sound too. That cat converter was probably never changed by any of the previous owners. Plus it has so many miles on it.
Old 11-10-2009, 01:18 PM
if your gonna replace it, look at rockauto.com. i got an eastern ceramic cat plus 3 day shipping for like 214. its good quality and fast service too. highly suggest them
Old 11-10-2009, 01:19 PM
heres a 5% off coupon code as well for rockauto. 24669832052495
