3.5 DOHC oil capacity - Nissan Forums : Nissan Forum
post #1 of 19 Old 02-01-2005, 06:50 AM Thread Starter
Just got the oil changed on the Altima, looks like the shop put in 4.5 quarts of Mobil 1. Should I drain a little bit of oil out or will it be fine?
-02 Silver/Black 3.5 SE Auto-
coldasice is offline
post #2 of 19 Old 02-01-2005, 06:56 AM
Cisco Systems Net Nerd
atx1975's Avatar
Are you thinking that they put to much oil? When I got an oil change they put int 4 quarts. I have 05 3.5 SE
2005 Smoke 3.5 Altima SE on 20"s
atx1975 is offline
post #3 of 19 Old 02-01-2005, 03:43 PM
I do my own oil changes and it takes 4.75 quarts every time.
R. Brown '02 V6 Altima Auto
rnbrn21 is offline
post #4 of 19 Old 02-01-2005, 04:33 PM
FabolousM's Avatar
Nissan says when you change your oil and oil filter for the 3.5 you should fill it with 4 1/4 quarts of oil. I usually put 4 1/2 courts.
Here is the link http://www.courtesyparts.com/altima/L31_specs.html
2002 Altima 3.5 Auto
XS Headers
13.8 @ 100Mph
FabolousM is offline
post #5 of 19 Old 02-01-2005, 06:51 PM
DPGC420's Avatar
I usually go with 4.5 quarts with the bigger Mobil 1 filter.
DPGC420 is offline
post #6 of 19 Old 02-01-2005, 06:55 PM
Always something better
I got a few friends who put 5 in
EDGE is offline
post #7 of 19 Old 02-01-2005, 10:08 PM
I have been putting in 4.75. Brings the level to the full mark every time.
jvitale is offline
post #8 of 19 Old 02-02-2005, 01:17 AM
i bring in 5qts of mobil 1 to the dealership.. I guess they put it all in?
donkeyponkey is offline
post #9 of 19 Old 02-04-2005, 11:14 PM
with mobil 1 #108, i put 1.25 quarts.
pewter1 is offline
post #10 of 19 Old 02-07-2005, 11:58 PM
There is this little "thingy" under the hood of you car.....its in the left front of your engine......its called a "dip stick".....you add your oil....then you check how much is in there with this "thingy"...its got a line that says....MIN....and one that says MAX....its REALLY cool.
So you add 3.5 to 4 quarts of oil.....start your motor....let it run for about 10 seconds...then you take that "dipstick" out again....wipe it.....put it back in....then pull it out....and check it again...and add oil accordingly....
quite the innovative tool..........lololololololololololol
dipsticks!!!.....lolol
ShagaDelic is offline
post #11 of 19 Old 03-22-2007, 07:55 PM
Anyone notice that the 07 v6 calls for 4 7/8 qts of oil. I looked at one and the oil pan looked the same, I wonder what the deal is
pcsgrp35se is offline
post #12 of 19 Old 03-22-2007, 09:57 PM
Majestic '06 3.5SE, 5 spd
froedrick's Avatar
Quoted: 1 Post(s)
4.5 'cause I use a Bosch which is larger.
Traded 10/10/11 for a 2012 Hyundai Genesis Track Coupe.
froedrick is offline
post #13 of 19 Old 03-23-2007, 02:49 PM
I usually put in 4.5 myself. Check the dipstick. Does it show over full?
bizarjuggalo is offline
post #14 of 19 Old 03-23-2007, 03:14 PM
I usually put only 4 with oil-filter changed
and 3.75L if no filter change
that quantity was written in the Instructions Manual
the ghost is offline
post #15 of 19 Old 03-23-2007, 03:43 PM
iTrader: 3 reviews
it'll burn out anyway
digitalbow is offline
