Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > Engine Performance (2002-2006)
  #31 (permalink)
Old 08-26-2008, 12:24 AM
Smokebaby's Avatar
AutoX killer!
Sweet! IwantIwantIwantIwant.
2005 Smoke SE-R 6 spd - AEM CAI, HLSD, Grounding kit, Stillen STB, Eibach Camber kit, Racingline MMI's, F&R endlinks, Axxtion STS, I/H/E, Nismo Suspension, UR UDP, NWP VIAS plate & IM Spacers, SS brake lines, JWT clutch & flywheel, TS Reflash
2008 Pathfinder LE 5.6 - Wifey's ride, bone stock (for now...)
  #32 (permalink)
Old 08-26-2008, 12:59 AM
NISSANCLUB SUBSCRIBER
Originally Posted by Adam West View Post
Just for curiosity sake, what made you choose a roots style over a centrifugal charger? Were you looking for more even power delivery? I'm sure you could've fit in a centrifugal with the jack shaft in that same amount of space. Anyways, awesome build man.
I was looking into fitting a 350z supercharger on it but that would have been a big job and finding a cheap kit for fiting purposes was not easy.
I saw a picture of an Honda accord with a comptech kit and I told myself that it would probably be easyer to fit. I Found a used kit on ebay back in december and bought it but unfortunately, the shaft was not nearly long enough. But at least it made me see that it was infact possible.
Centrifugal, I have a friend who has an Eclipse V6 with a RIP supercharger and on the street it is fine but the sound at idle is not good at all. You can always ear the inernal gears running and I did not like that at all.
Originally Posted by kasey07 View Post
not to be a party pooper but there has been a procharged 3.5 in ohio for a couple years. he is some old guy not on any forums or anything and he has like 15k miles on it supposedly it never comes out of the garage. also what did you need for the 6 speed swap was is just the trans and axles?
Not a party pooper at all; as far as I knew, there we're only a few solution for this.
- Extended shaft like me which I do not think is the case.
- Remove the air conditionning to make place for the supercharger.
- Replace the complete timing cover and put the 3.0 liter timing cover on and then fit a stillen 3.0 supercharger kit. (If I remember correctly, in this cae they are loosing the variable cam)
Anyway these are the options I heard about.
Transmission swap for the 6 speed. Swich over the speed sensor from the 5 to the 6 speed transmission (the six speed does not have any but has everything to install it. Nothing else required.
Originally Posted by Flame1 View Post
How many horses are you shooting for?
I am shooting for around 400 whp but I do not think i can get there without forging! (or if I get there, it won't last long)
2002 Altima 3.5 SE 6Sp HLSD
MP90 Supercharger, S-Max Intercooler
Fidanza & Exedy Stage 1
Tein SSP & EDFC & Hood Damper
Stillen Body kit, Front Bumper
Nismo cams
XS Headers, Dual Exhaust, Stillen Mufflers
Nismo Forged Wheel 18x8.5" & 245/45/18 & TPMS
Brembo G35 Brake Front & Rear
Greddy Boost, Oil, EGT, FJO Racing Dual Wideband
Winter car: 2008 Dodge Avenger R/T AWD
  #33 (permalink)
Old 08-26-2008, 01:19 AM
kasey07's Avatar
shift_wheel hop
i just wanted to say im not knocking what you have done at all its a great accomplishment. 2nd what did the trans run you?
  #34 (permalink)
Old 08-26-2008, 02:17 AM
spike228's Avatar
Mark of Shame
That's freakin awesome. Very nicely done! It sounds like a beast.....nice kill too.
Cardomain
Mods:
| Apexi V2 | Hella Optilux 1180 / Apexcone 3000k | Polk DB6500 + Polk DB690 | Apexcone 5000k | Racingline FSTB | Nismo Catback | AT S5 | Nismo 57F / Potenza RE01R; 245 45 18 | Redline Quicklift Elite | Hotshot header | Jihad folding mirrors | Nismo RSB | Audi DRL | Tein SS w/ EDFC | Racingline MMI | 350z seats | JWT BSR |
Testing: RedLionRacing Traction Rod Prototype
  #35 (permalink)
Old 08-26-2008, 02:27 AM
allblackmax's Avatar
This was just posted on the maxime.org forum and trust me, you'll be getting plenty of inquiries soon. Nice work! This is the first time seeing this done.
'04 Max, AEM Intake, Hotshot headers, Greddy cat-back, APEXi SAFC II-tuned, Eibach springs, Koni strut inserts, KYB AGX, Stillen RSB, Racingline endlinks, Brembo rotors, Hawk HPS pads, Dunlop Direzza tires, E&G grill
  #36 (permalink)
Old 08-26-2008, 03:30 AM
Don't worry, I did not take it his way. Sorry if it looked like it. My first language is french so I may make some mistake when wording a sentence.
I was just wondering how it was done. I search a lot on many forums and never heard of this one. I was curious to see it as well.
Transmission was 1000. It was not cheap but there was not many of them in Canada and I did not want to have to import it.
Thanks, i was wondering when it would come out there as well.
  #37 (permalink)
Old 08-26-2008, 05:54 AM
Leathe of Heaven's Avatar
uR t@k signlz blngz 2 m3
So it's a Honda Comptech Kit? Part number?
How did you make the extended shaft? Any part numbers on that?
14.320 @ 99.82 2.178 60' (DA Corrected: 13.98 @ 102)
XS/SSAC, Magnaflow, AXXTION, Redline, KYB, Koni, Racingline, ATE, JWT, Dynotune, Nitrous Express, ColdFusion, Energy Suspension, MonsterKnob, NISMO, R1Concepts, DDM Tuning, V-LEDS, Kicker, Memphis, Second Skin, Ichiba, NGK
1996 Nissan Pathfinder SE (VG33E) 4X4
Just the beginning..
  #38 (permalink)
Old 08-26-2008, 06:03 AM
20s because size matters
This also got posted on NYCmaximas.org and some guys over there are really impressed.
Not to pry, but I hope you can share on key tips with your install. Thanks.
I have been toying with a self oil procharger and mounting it in place of the a/c compressor. Just have not had the time to get into it.
My CardomainCtmaximas
  #39 (permalink)
Old 08-26-2008, 01:56 PM
TUKO316's Avatar
2 low 4 fat hoes!!!
i suggest selling the brackets and shaft. he could make a killing
2005 ALTIMA SER 6SPEED
-ENOUGH MODS TO WHOOP YOUR ASS!!!!
-THIRD PLACE IN V6 N/A DYNO COMPETITION AT
NOPI NATIONALS 2006.
Originally Posted by swat1279 View Post
Tuko316, that vortec cyclone that you mentioned,ordered 2 and works great. I got great gains Thanks. Oh and your car is sharp dude.
  #40 (permalink)
Old 08-26-2008, 03:58 PM
Agreed.
  #41 (permalink)
Old 08-26-2008, 04:54 PM
bigjeff26's Avatar
i was working with N2MB trying to get this accomplish (the stillen way as u mentioned) but we didnt like the idea of losing the Variable cam either....and i didnt want to lose my A/C compressor either..so this is awesome to see....seriously man u can really sell you ideas and "scematics" LOL to someone to mass produce ..you took all the R and D out of it for them...and i am sure that it would sell with out a doubt ..i would so love a low boost s/c kit just for that sound hehe
  #42 (permalink)
Old 08-26-2008, 05:44 PM
TUKO316's Avatar
2 low 4 fat hoes!!!
me too. nuffin like loud obnoxious whinning sounds from ur hood. just wish it could b cheaper to piece together. but still none the less an awsome mod. the creativity that went into this is amzing. that shaft is basically wat we all need to make tis possible
  #43 (permalink)
Old 08-26-2008, 06:26 PM
I am not saying I am making a kit, I am only trying to make a list of everything required.
The kit would need to be composed of (mechanical parts only, no electronic or tuning):
- Supercharger, Pulley and special shaft (The OEM version of these supercharger will not work with the two piece snout assembly.)
- Tensioner and Tensioner Bracket
- Left & Right bracket
- Thermostat Housing.
- Input & Output Radiator Hose.
- Supercharger Air Intake housing and Air Filter
- Supercharger Air Output Housing. (Different model with or without intercooler)
- Alternator Pulley
- New Main Drive Belt
- Supercharger Belt
- Intercooler Piping ?? (If Intercooled, would be recommended)
- Intercooler ?? (If Intercooled, would be recommended)
- Maf Adapter (If you blew your MAF in N/A then with this, it is going to be worse. You will ned to switch to a more powerfull MAF or to a MAP like I did and adjust the signal using a piggy back)
- Blow-Off (You need one since the supercharger is in front of the Throttle Body)
You would need to supply anything els and have the tuning done by you.
- Injectors (I am using 440cc for now)
- MAF or MAP ??
- Battery will need to be moved in the Trunk (the use of a very small battery could be possible in the engine compartment, would need to be checked.)
- E-manage Ultimate, Utec or some other piggy back that may fit our cars
- Of course when you have a car like this, it is always recommended to have a Wideband (Air/Fuel Gauge) and a boost gauge.
I made this listing quickly so I may have forgotten a few things.
  #44 (permalink)
Old 08-26-2008, 07:27 PM
Blacktop_Prefect's Avatar
Positive Contact
Did you street tune it yourself? Any quirks or issues there?
The darkest side of humanity animated.
  #45 (permalink)
Old 08-26-2008, 08:04 PM
Yes, I did tune it myself on the street and on the track.
Of course, there was a few "quirks or issues" here and there, it was my first FI tuning project.
But all of these had solutions.
The only one left is probably due to a bad design by Nissan, but I did not dig deeply to find the reason or a sollution to the problem.
On the track, I have have less than a 1/4 of a tank of gaz, the fuel pump will start to pump air just before the end of the Quarter Mile. The reserve inside the fuel tank is probably located too much toward the front of the tank. With a long and hard acceleration, the fuel is probably all going in the back of the tank, leaving the pump breading air when the reserve is empty. Anyway, this is my deduction so far. I would need to remove the fuel pump and check the tank configuration to be certain.
When it first happend, I was like "what the ... is happening?". I started to log each run and saw that the more I was racing, the sooner the problem would happend. So to make a test I went out and filled the tank to half. The problem disapeared.
It happend to me a second time but this time i had a 5 gallon ready.
That is the first time I aw or heard of someting like that!
