ECU Reset - Nissan Forums : Nissan Forum
post #1 of 16 Old 06-05-2009, 02:20 PM Thread Starter
AKA Moving Violation
Silverbullet02's Avatar
Question ECU Reset
So I caled the dealer yesterday to ask a question about reseting the ECU and the tech told me that they could do it with the consult but you could get the same reset if you disconnect both batt terminals and then touch the two terminal ends together. He said that will drain the capasitors that hold the ECU memory. He also said that is should work for those times when you have to do the idle relearn. Has anyone tried this? does it work?
SILVER BULLET SOLD!!!!
GUYS I AM PRACTICLY GIVING AWAY PARTS CHECK OUT MY THREAD IN THE MARKETPLACE!!!!!!!!!
Silverbullet02 is offline
post #2 of 16 Old 06-05-2009, 02:50 PM
Ctrl-F Yourself
200hpAltima's Avatar
Quoted: 2 Post(s)
electronically it makes sense. I back-up my computer to my flash drive and then hold the power button to drain the capacators there. So i imagine it would work. I would try it and see what happens. It wont hurt your car at all. Hope this helps
200hp
E-Racings Front|Tint|Tsudo Catback|Verde 18's|Woodgrain Dash Kit|Tinted Tails|Vinyl Behind Mirrors| Too Much to List!
DIY LED Tursignals In Mirrors|DIY Projector Retrofit|What You Need to Convert to OEM HID|Nissan Factory Service Manual Here|How To Check/Clear SES Codes HERE|Upgrading The Stock Halogen Headlights|Detailed Description of HID and Angel Eyes
BEST IN CLASS AT 2009 CANAL DAYS CAR SHOW!
Originally Posted by KeVQ35 View Post
Your car is like the ugly chick that all the guys look at in disbelief, but she tells all her girlfriends that guys are constantly checking her out.
200hpAltima is offline
post #3 of 16 Old 06-05-2009, 10:31 PM
Synergy's Avatar
Did you try this? I'm curious...
Nismo Cold Air Intake | Active Tuning Grounding kit | SE-R Tail Lights | Tints | Unorthodox Racing Crank Pulley | Black Nismo License Plate Bracket x2 | Racingline FSTB | Racingline Battery Tie Down | Magnaflow Catback Exhaust System | Racingline Y-Pipe | White turn signal bulbs | NWP VIAS Block Plate | Racingline Motor Mount Inserts | AEM Dryflow Filter | Nismo Radiator Cap | Nismo Oil Cap | HIDS waiting to be installed. | Jihad Folding Mirrors | Racingline Springs | Kyb GR-2 Shocks and Struts | Resonator Removed | Headers! (Need to be installed) Pm me if you can, NYC area
Synergy is offline
post #4 of 16 Old 06-05-2009, 10:43 PM
Winner March 2010 NOTM
hattrick3518's Avatar
Quoted: 3 Post(s)
do this and tell me if it works! i blew my maf and need to reset my ecu when its all done... i dont wanna pay $109 to the dealer.
let me know if this works
you can pm me again if you want too ha
hattrick3518 is offline
post #5 of 16 Old 06-06-2009, 05:46 PM
zoom zoom
3rdgen2.5s's Avatar
Even if it doesn't work just leave the battery unhooked overnight. Either way there is no need to pay the dealership 109 to reset the ecu.
2006 Mazda 3 2.3 5MT-NEW
2005 Altima 2.5s 4AT-GONE
2007 CX-7 2.3T AWD 6AT-WIFE'S
3rdgen2.5s is offline
post #6 of 16 Old 06-06-2009, 06:17 PM
Code Red
SE-R Tuner's Avatar
Lol not trying to be a dick hear but you guys really want to know if it works...newbs lol jk? Well I can without a doubt tell you it works. Done it many times on many cars, it works perfectly fine...
^Not your average 4-door^
No tune 5 A/T
60' 2.03
13.91 @102.37
SE-R Tuner is offline
post #7 of 16 Old 06-06-2009, 07:21 PM
Quoted: 3 Post(s)
i have left mine undone overnight to no avail...
post #8 of 16 Old 06-06-2009, 07:58 PM
Code Red
SE-R Tuner's Avatar
...I dont know how you could have left the battery terminals disconnected over night and nothing has happened. I mean I've left mine disconnected with the - and + touching for like 15 or 20 min and it reset my ecu. I've done this on my Z, Alti, mustang, lightning, etc. and worked everytime...
No tune 5 A/T
60' 2.03
13.91 @102.37
post #9 of 16 Old 06-06-2009, 08:09 PM Thread Starter
Just un hooking them overnight will not do anything. you have to hold the + and the - together for 5 minuites so that it will drain the capasitor. The capasitor will hold enough power to keep memory in the ECU for a couple weeks. I did it to mine yesterday and it works
post #10 of 16 Old 06-06-2009, 09:40 PM
Quoted: 3 Post(s)
ok cool, i had my maf go and i need to reset it once its all taken care of... glad this will save me $109 ? ?
post #11 of 16 Old 06-07-2009, 05:07 AM
Code Red
SE-R Tuner's Avatar
Well maybe my capactiors in my ecu are broken or missing cause i could make a vid right now of me just disconnecting my negative terminal for 15min and then hook it back up and my ecu will reset. But hold the + and - always works as far as I know...
No tune 5 A/T
60' 2.03
13.91 @102.37
post #12 of 16 Old 06-08-2009, 02:25 PM
My little champion...
KeVQ35's Avatar
Quoted: 19 Post(s)
iTrader: 3 reviews
I think some folks are confused and think that disconnecting the battery will clear the ECU codes (SES light).
To the OP, as far as idle volume learning. My idle is high after having the air induction cleaning or whatever they call it. I've done the foot pedal procedure and it works right after, but not after the car has been sitting for a while. I got some paperwork from my mechanic about disconnecting one or two injectors and trying to have it learn that way - crazy @ss electronics these days...
KeVQ35 is offline
post #13 of 16 Old 08-05-2011, 06:58 AM
ok..double checking here..dont feel like frying nothing ..i know this post is old..but better safe than sorry... if disconect both terminals...and then hold the two cable connectors togethor for a short time.. it will drain the copasiters and reset the ecu...and turn of the ses light?
LordBear is offline
post #14 of 16 Old 08-05-2011, 01:04 PM
Altimer
Mike James's Avatar
Quoted: 68 Post(s)
Just do this:
http://www.nissanclub.com/forums/f-q...oon-light.html
Do you know why your light is on or what codes your getting?
Altima traded for Odyssey
Current - 08 HIGHLANDER
Mike James is offline
post #15 of 16 Old 08-05-2011, 08:27 PM
Originally Posted by Mike James View Post
Just do this:
got gas the other day and when i started up the car the light was on..so later when i had the chance i checked the gas cap ..it was fine and then went thru the list and checked the oil and it was low.. so fixed that then put a reader on the car. to be on the safe side and it gave me the code.. poo11 or something..any how saying my timing is advanced to far ..researched on here and found it is a common thing . for low oil and a cam position sensor. and going off just cuz it wants too..lol
LordBear is offline
