NTB07-042c - Timing chain - Nissan Forums : Nissan Forum
 5Likes
post #1 of 91 Old 10-10-2011, 01:53 PM Thread Starter
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
For this TSB, has anyone replaced only the tensioner? Is this a lot less work than doing the entire job? Can it be done easily with the engine in the vehicle? I know that top plate can be removed a lot easier than doing the entire job, but is that where the tensioner sits?
nismos14 is offline
post #2 of 91 Old 10-11-2011, 07:30 PM
Shaving My Shoulders
RIZAMAN's Avatar
Quoted: 276 Post(s)
Wow man...Been looking through the FSM on this. Huuuge job just to get in. Even though the FSM will most of the time indicate you have to do more then you really do, it still looks daunting. It does not indicate the engine needs to be removed.
TSB does mention it's the secondary chain tensioners - at least they're up top.
EDIT...On second thought - check this..
http://ww2.justanswer.com/uploads/fi...e_bulletin.pdf
|2013 G37S|CURRENT|
|2005 3.5SE|TRADED |
Originally Posted by Penguinchit View Post
All you G owners suck balls.
RIZAMAN is offline
post #3 of 91 Old 10-11-2011, 08:49 PM Thread Starter
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
Hopefully the shop can do it for a reasonable amount.
nismos14 is offline
post #4 of 91 Old 10-13-2011, 03:11 AM
edjose17's Avatar
You need to replace the secondary timing chains also, since they are the root cause of the problem.
The only shortcuts to this job is to use the ring gear stop tool as the TSB describes, this avoids having to remove the valve covers and intake manifold, saving a couple of hours of work.
It can be done with the engine in the vehicle, only the outer timing cover needs to be removed. Its very tight in space but possible.
I did this job on my 05, let me know if you need any help.
EdJose
edjose17 is offline
post #5 of 91 Old 10-13-2011, 10:49 AM Thread Starter
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
I need help, come here and do it for me! Lol I got a quote from a reputable shop that I've been to before for $800 including parts and all. I think that's pretty fair.
nismos14 is offline
post #6 of 91 Old 10-13-2011, 04:34 PM
2008 Max SE
iTrader: 3 reviews
Just curious; How many miles do you have?
Discipleof23 is offline
post #7 of 91 Old 10-13-2011, 04:54 PM
RIZAMAN's Avatar
Quoted: 276 Post(s)
Good question...I am NOT looking forward to having to deal with it...
|2013 G37S|CURRENT|
|2005 3.5SE|TRADED |
RIZAMAN is offline
post #8 of 91 Old 10-13-2011, 11:10 PM Thread Starter
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
nismos14 is offline
post #9 of 91 Old 10-15-2011, 02:45 PM
RIZAMAN's Avatar
Quoted: 276 Post(s)
Shiit...107,XXX for me
|2013 G37S|CURRENT|
|2005 3.5SE|TRADED |
RIZAMAN is offline
post #10 of 91 Old 10-15-2011, 03:24 PM Thread Starter
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
Might be coming, sell it fast.
nismos14 is offline
post #11 of 91 Old 10-20-2011, 02:43 AM
I had mine done for my 05 altima for $460 at dealer @95K miles.
najfario is offline
post #12 of 91 Old 10-20-2011, 07:29 AM
iTrader: 3 reviews
How much $ did you spend and how long did it took you to do it?
Arturo
2005 SE V6 Auto 5spd
Nizzan300ZX is offline
post #13 of 91 Old 10-20-2011, 11:01 AM Thread Starter
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
Where do you live? What dealer? This was done on a 3.5 correcT?
nismos14 is offline
post #14 of 91 Old 10-20-2011, 12:25 PM
RIZAMAN's Avatar
Quoted: 276 Post(s)
$460 at the dealer? Win.
|2013 G37S|CURRENT|
|2005 3.5SE|TRADED |
RIZAMAN is offline
post #15 of 91 Old 10-20-2011, 02:03 PM Thread Starter
~ fk
nismos14's Avatar
Quoted: 27 Post(s)
iTrader: 24 reviews
The parts alone are sold for like $400, something's not right about that.
nismos14 is offline
