Originally Posted by 702L32
yeah that lower yellow arrow on the bottom right.. air will fill up that chamber and flow left into the original duct work. unless you can make an opening all the way into the area you have in red
yup. that is the idea in the process. once the read area is opened the flow will be as drawn. i might have to seal or create a left wall on the right vent opening.
as for the throttle i was offered an VQ throttle, but im investigating if it uses the same one or a better one.
as for the manifold, thanks to nssan i had to opt for a top speed header. the original blew on the cat weld and made a one inch hole. the new held held up (started to tear) to when the headers came. and the oiginal cost $589... thanks nssan.
