Walbro Fuel Pump Install Complete w/ pics - Nissan Forums : Nissan Forum
post #1 of 1 Old 02-12-2005, 03:43 AM Thread Starter
It's Paid For.
SuperAlty's Avatar
Walbro Fuel Pump Install:
Please take the proper precautions as you will be dealing with fuel vapors.
Remove fuel pump relay, run car until it dies.
Remove negative cable. Loosen gas cap.
Remove backseat (you have to figure that out) Upper and Lower portion.
You will see the fuel pump access cover held down by 4 10mm bolts, remove them.
Under the cover is the fuel pump access.
Remove electrical connections and fuel lines. Be very careful as to not harm those lines.
Using your own method remove the black lock down ring.
When the ring is off you can lift up on the upper assembly. You need to remove the 2 electrical connection and 2 fuel lines. The upper assembly will now be out of your way.
Follow the directions that came with the pump to remove the fuel gauge float assembly and the pump.
Old pump, bracket and new pump.
Move the electrical connections and fuel line to the new pump. Install pump into foam sleeve, and lock in the bracket. Lock on the sock and you have a new complete fuel pump assembly.
Old filter 160,000 miles, new filter pretty and white
Install is reverse of removal.
Test.
Originally Posted by hotlicia
..... i hate women that drive, they fukin suck at it
SuperAlty is offline
The Following User Says Thank You to SuperAlty For This Useful Post:
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 1993-2001 Nissan Altima Forums > F.A.Q 1993-2001
