i know thats a factory bent hose, but i used a regular ole section of heater hose.
Originally Posted by Rick
asleep is a stream of off-color and low-cooth jokes in person as well. I've been recycling jokes I heard from him for years. He is known by my friends as "the sick fuck."
Originally Posted by trmn8r
seems like you just killed someone with your Daewoo Lanos Asleep. lol
if you tighten the heater, fuel or other hoses too loose they will leak after 1-2 month.
I tightened those hoses around intake pretty well. but did not tighten heater hoses around radiator. so one of them started to leak and had to be replaced. then I checked all clamps. there were all loose. so I tightened them up again.
that's after 2 months
those are vacuum hoses. I think 5mm. measure the aluminum pipes with caliper and buy vacuum hoses 1-2mm smaller in diameter.
so if that aluminum pipe for hose is 5mm. you should get 4mm hose.
im going to attempt to replace my intake manifold gasket with a buddy of mine this weekend. I have a 2000 altima gxe and I've got the gasket already, but what kind of sealant and coolant do I need to get?
I especially like the photography with graphic "call outs".
As a novice, just trading a 91 ford explorer for a 99 Nissan, I've figured out where the battery, fuses, spark plugs, valve cover, PS, power brake, etc is. But, there are some new items, especailly polution control devices, and I see acronyms like: EGR pipe, IACV, ECU, HUD & ATC
Is there a graphic available that shows the location of all these devices and what the acronyms mean?
Thanks,
__________________ Jay R.
1999 Nissan Altima GXE
If you can read this, thank your teacher.
if you can read this, thank your Systems Engineer.
NO RTV! If you want to use anything, use Permatex copper spray adhesive,otherwise, leave it dry!!!
93' Altima KA24DE!
Fix it now! When it is right, not when it is very $$$ to fix!!!
Revenge feels so good!
