How-to: Adjust Headlight beam - Nissan Forums : Nissan Forum
post #1 of 4 Old 12-03-2002, 02:40 AM Thread Starter
Altimas.net
JBL85's Avatar
How To: Adjust Headlight beam and Fog Lights
Head Light Adjustment
Fog Light Adjustment
Drivers Side Head Lamp
Passenger Side Head Lamp
Adjustment
JBL85 is offline
post #2 of 4 Old 12-03-2002, 11:11 PM Thread Starter
Altimas.net
JBL85's Avatar
Originally posted by Deetech
You can adjust without removing anything. If you look close, there are teeth visable from directlly above, under the bolt mentioned. Using longish flat blade screwdriver, you can turn the bolt by rotating the screwdriver one tooth at a time. Dosnt take long.
I recommended spending 5 minutes to take out the intake and washer fluid/coolant tanks, makes access much easier and saves yourself from srapping our fingers trying to get into the nooks and crannies.
JBL85 is offline
post #3 of 4 Old 12-04-2002, 11:47 PM
Hey JBL85;
I'm going to take the assumption that turning the bolt in (clockwise) will raise the point of aim, and turning it out (counter-clockwise) will lower it. Is this correct?
PVick
2004 Acura TL
Anthracite/Ebony
6sp Manual trans
Navigation
Drop dead Gorgeous
pvick is offline
post #4 of 4 Old 12-05-2002, 02:30 AM Thread Starter
Altimas.net
JBL85's Avatar
pvick, from the angle I took the pictures, that is very correct, I should probably add that into the how to info huh?
JBL85 is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > F.A.Q 2002-2006
