Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2007+ Nissan Altima Discussion > F.A.Q 2007+
  #16 (permalink)
Old 04-10-2007, 05:07 AM
Master of the UOA
That's a different procedure. You should be able to find it with a search.
  #17 (permalink)
Old 04-22-2007, 07:11 PM
I tried to set the diagnostic mode, but after a couple of attempts, I gave up. I never got the light to the flashing stage. I'm guessing that my timing was off- is that what was meant by "meticulous with each step"? (actually, I was trying to get the idle air volume to "learn", but the steps are pretty much the same. I didn't get the MIL to flash, but it does idle better/slower)
  #18 (permalink)
Old 04-23-2007, 12:52 AM
gtcompscientist's Avatar
Troll Sniffer
Meticulous does mean that you have to be VERY precise with the timing. Not exact, but almost.
Charles
2008 Pro-4X Crew Cab
Stillen C.A.I. :: Stillen Long-Tube Headers :: Stillen Cat-back Exhaust
Painted Badges :: Headlight Mod :: Tinted Taillights :: Tinted Windows
Power-lock Tailgate :: ScanGauge II :: 2* Advance
2007 Altima 3.5SL
25% Tint | Navigation Hack
Got Manuals?
  #19 (permalink)
Old 05-05-2007, 03:55 PM
07 black beauty
Originally Posted by confess00
yes i am not to sure what all of these codes mean either but my air bag light keeps on flashing is there a way that one of these codes will reset it so that the light stops flashing?
i just had that yesterday and took to the dealership and they cleared it for me for free...my light came on after i was messing with the head unit...dont know why it came on and neither does the dealership but it did...probably have to take it back to have it cleared again once im done with my custom nav/unit install...
  #20 (permalink)
Old 07-10-2007, 07:01 PM
Foglght's Avatar
Rub my fender
I don't know if this would help but I have the same issue with the airbag light after my stereo install. I had a Titan with the same problem, and there is a reset procedure for those. It might work for the Altima. I'll have to check it out and see if it works.
Do I look like a cat to you boy? Am I jumpin' around all nimbly bimbly from tree to tree? Am I drinking milk from a saucer? DO YOU SEE ME EATING MICE?
  #21 (permalink)
Old 07-11-2007, 06:20 PM
I actually just did a google seach a while ago on nissan air bag light and I found a procedure but I wasnt sure if it was for the 07 or not. I tried it out just to see if it would work and it did.
here is the link
Diagnose Problems Nissan Altima
  #22 (permalink)
Old 07-12-2007, 07:15 PM
Foglght's Avatar
Rub my fender
here is the link
That is the same procedure I used for my 2005 Titan. I will test it out tonight and see if it works. The procedure was very picky in my Titan.
  #23 (permalink)
Old 07-17-2007, 03:00 AM
Foglght's Avatar
Rub my fender
I reset the light tonight, the procedure works.
  #24 (permalink)
Old 07-20-2007, 04:51 PM
jlohcc's Avatar
Thanks for posting the airbag light reset procedure. Worked perfectly on my 07.
Anything...and everything is possimpible
  #25 (permalink)
Old 11-14-2007, 02:40 AM
Worked, Cleared my SES light, you have to be very meticulous, I tried a bunch of times before I finally got a stop watch to time it perfectly.... Get a watch and follow the instructions...
  #26 (permalink)
Old 11-19-2007, 03:24 AM
imd12nv's Avatar
I just reset my airbag light. Why do they go on after installing a headunit? I love this forum
  #27 (permalink)
Old 11-19-2007, 03:59 AM
Nissan4LIFE's Avatar
Flux Car Club Member
The airbag light goes off if you unplug the plug for the airbag off light in the center vents and turn the car on because the airbag system is looking for all connections to complete the circuit and if the light is not there then it throws up a code. If you do not unplug the center vents then it won't go off. ITS THAT EASY!!!
2007 Altima 2.5 SL CVT Radiant Silver
Error - Amount of MODS exceeds space provided. Click for CarDomain
I'm a proud new member of the Flux Car Club
Sponsored by: BlueBatmobile.net "AUTHORIZED INSTALLER" | AIT Racing | Racingline | Killerglass | Clear-Pro Invisible Auto Bra
Threads: Subwoofer Enclosure | Air Suspension | Carputer
Become my follower today: http://www.twitter.com/Nissan4LIFE
  #28 (permalink)
Old 11-19-2007, 07:13 PM
imd12nv's Avatar
That makes perfect sense
