Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2007+ Nissan Altima Forums > F.A.Q 2007+
Old 11-27-2008, 07:57 AM
How To: DO AN OEM XENON HID Headlights Conversion
Hi all, just feel like sharing my method of converting halogen to OEM Xenon HID headlights for 4th gen. I have done this with my other 3rd gen, so I just learnt from past....
In Canada, our Altimas don't get OEM HID unlike the states do except the 3.5SE Coupe with Leather Package. So have to look south to get my self a set of lights. I got lucky and brought a set of brand new lights on ebay for around $450, you CAN get this for much cheaper used and since I am in Canada, that 450 includes a lot of postage fee. So is not that bad actually considering you saved yourself over getting that Technology whatever package charged by Nissan dealers.
I know people will swear by kits, but this is completely different story here. I want that clean OEM look, and also for practicality. This is done on a CANADIAN MODEL 3.5SE. Is the same for all the USA models without HID as standard. If you get a used pair, get one from the same vehicle because each bulb on different cars might be used differently, hence, the colour(color) will be different.
anyways...enough personal opinions...
DISCLAIMER: I am NOT responsible for any of your injuries or damages to yourself, to others, to any properties as this is just a basic guide for modding your car. I am not liable for any thing here!!!
What you need:
  • -Pair of OEM Altima headlight. Part number: 26060-JA10A and 26010-JA10A
  • Relay harness to protect your fuse and your car's electrical circuit. Is a cheap insurance anyways. I know ppl will say they don't need it, but this item will come in useful later as you will see why....
  • OEM piggy wires that goes into the ballasts (to be solder with the relay)
  • tools, whatever suitable for the situation
  • time, I did this in 5 hours because I am very picky, you can do this in less than 2 hours.
  • a friend maybe to help you hold the bumper, give you some drink and food once in a while I guess? I didn't have any around thought...
  • electric tape, you can use shrink wrap for better seal, strongly recommended
  • zip ties
a pair of headlights, zip ties, relay, tape (notice the bracket below the headlight, is there for security purposes, you don't have that in the halogen version)
http://i25.photobucket.com/albums/c6...8/DSCF8327.jpg
showing the back
Making your relay harness
Got this off from ebay, but even though it said H11 wire, the connector is actually a 9006 or something. So you have to buy this :
Once you got both, strip the wires from both the piggy wires and the relay wires and solder them together
http://i25.photobucket.com/albums/c6...8/P4195491.jpg
http://i25.photobucket.com/albums/c6...8/P4195495.jpg
you will have something like this:
[url]http://i25.photobucket.com/albums/c66/wai_jai268/P4195494.jpg[url]
Do this for both sides of the headlight, and these will be used to plug into the ballast for the new headlights.
Explanation for relay installation:
Some of you have been pm me and asking me how to do a relay and whats it for, here is a picture. I hope it helps. For more information on headlight and other related item if you want to read more, go to http://faqlight.carpassion.info/ and www.hidplanet.com .Tons of INFO!
Pretty much self explanatory. So the relay get a signal from the low beam connector signalling a need to draw power from the battery, the relay only takes 0.1amps or less to trigger it. Then the relay draws the current from the battery to supply the two ballasts. How do you want to run the wires depending on you, I ran the wire under the bumper away from sight.
Procedure for installation:
1. Park your car on a flat surface with lots of room around and open your hood. Mark your headlight cutoff so later you will match the original cutoff line later after installation.
2. Disconnect your battery, notice how I tape the negative cable wire so to prevent accidentally touching the battery terminal
http://i25.photobucket.com/albums/c6...8/DSCF8339.jpg
3. Taking off the bumper. Many of you will know this so I am going to keep it simple. Pop those clips on top of the grill
http://i25.photobucket.com/albums/c6...8/DSCF8332.jpg
4. Pop those clips at the bottom of the bumper
http://i25.photobucket.com/albums/c6...8/DSCF8334.jpg
5. Unscrew these for each side of the bumper.
http://i25.photobucket.com/albums/c6...8/DSCF8337.jpg
6. Drop the bumper, remember to remove the fog light wires if you have them.
7.Remove the headlight by unscrewing 4 screws for each headlight. 3 on top, and one on the side.
8.Remove this harness at the bottom of the light.
http://i25.photobucket.com/albums/c6...8/DSCF8341.jpg
9. There some clips holding on to the driver side headlight, if you try to pull the light, you will feel something holding the light, you might need to reach your hand at the back to unclip it. For me i just snapped it. For the passenger side, you don't need to unsnap it.
10. Remove light, unplug everything.
http://i25.photobucket.com/albums/c6...8/DSCF8343.jpg
11. Install relay.
http://i25.photobucket.com/albums/c6...8/DSCF8355.jpg
12. This step take a little observation to understand. Find your low beam plug. Remember the relay I made earlier, you have to use the signal wire from the relay and plug them into the H11 connector from the car. Follow the pictires. This method does not need to splice your car's wire!!!! No clipping and splicing. Use tape to cover the connection. or use shrink wrap.
http://i25.photobucket.com/albums/c6...8/DSCF8344.jpg
http://i25.photobucket.com/albums/c6...8/DSCF8345.jpg
http://i25.photobucket.com/albums/c6...8/DSCF8347.jpg
See this perfect connection, no splicing and clipping:
http://i25.photobucket.com/albums/c6...8/DSCF8357.jpg
http://i25.photobucket.com/albums/c6...8/DSCF8359.jpg
12. install light. Do the above with the other side of the headlight. Don't forget to screw this little security bracket as well under the light.
http://i25.photobucket.com/albums/c6...8/DSCF8364.jpg
13. Test out the light if they work or not. Connect the relay power if you haven't already done so.
14. Adjust your beam, the adjustment screw is on top of the light.
15. Reinstall bumper and everything.
16. This step is not neccessary but might be needed. It is common for the Altima to have problems with auto-up window or airbag light turning on after disconnecting the battery. For the window problem:
1. turn your key to "ignition on" position (you know what i mean, push the push button to ignition on )
2. depress the driver side window to a bit below half open, then hold the driver side window until its fully closed, and continue to hold for 5 seconds.
3. open fully and test the auto-up function to see if it works.
4. do this for other side of the window.
I don't know how to solve the airbag issue though...so.
This is my own write-up. I am not a first notch instruction writer, so please forgive my crappiness.
thanks. good luck on your project!!!
Old 11-27-2008, 12:24 PM
Great write-up.
If u don't mind i'll add some to it.
If i don't wanna play around with pigtails much (or in my case wasn't really sure which ones to use) u can just cut&splice.
Now i got a queston:
Can u eleborate more on relay? I didn't intall it and have no issues. What it is for?
2008 2.5S w/ conv pkg
18% tint, autostart
OEM 3.5 HID headlights, 3.5 side led mirrors
OEM fogs w/ stalk switch
OEM autodim mirror w/ compass
OEM leather, spoiler
DNX5140 w/ swi-pac & CCD-2000
Polk Audio comps, sub, 2 amps
In&exterior LED swap, dual led turn signal
DEPO led tails
Redline hood lifts
K&N WAI
Stillen RSB
RL's Strut Bar, endlinks, battery tie-down
KONIG FURTHER w/ 245/45-18 Yakohama Advan S.4
Old 11-27-2008, 07:31 PM
eskalaid's Avatar
BoSs DoN bIG WaVeY
any of you guys have pics of them i was thinking about going oem or retrofitting but both are costly..also i had made a post about puttin oem hids in my fogs do you think that would work or would be over kill
02 to 08
08 2.5s Mods
Oem fogs
Oem spoiler
8000k hids headlights and fogs
Debadged
Stillen front lip
Ebay sports mesh grill
08 G37s coupe rims (summer)
07 G35 sedan 18s (winter)
Hyper white leds inside & out
Magnaflow race series Exhaust
Fujita short ram intake
Mods to come rear valance black roof ..
VOTE FOR ME NISSAN OF THE MONTH..
Old 11-27-2008, 07:36 PM
^^^ what do u mean pics of them?? They look 100% just like halogen ones.
Old 11-27-2008, 08:43 PM
Awesome write-up. I'll add it to the FAQ Forum if you'd like.
Is it possible to have all your pics appear in the thread with the tags?
3.5SE M/T
Old 11-27-2008, 09:47 PM
Originally Posted by Vital View Post
Great write-up.
To reply to your question, relay is just a way of pull the juice directly from the battery and avoid pulling the juice from factory wires. I am not sure if the factory wires can sustain the constant high power flow, and don't know the long-term effects, and to avoid costly repairs in the future seeing people melting their factory wires. you might have no problems now, might have big trouble in the future though. Pulling electric power direct from battery ensures i have a consistent power from the battery which might prolong the ballasts life too. I just be on the safe side and buy a relay for 15 bux, is like buying cheap insurance.
the overall installation is cleaner too, no cutting factory stuffs...
i have been using OEM hid on my other altima for 3 years, never have any flakering issues, never replaced anything yet......
Old 11-27-2008, 09:48 PM
Hi,
sure if you want to add to faq
the forum limits my possting to only 10 images, if i put more than it will all be in url
is this what your referring to?
Old 11-27-2008, 10:10 PM
Agent00Alti's Avatar
Gotta beat the RSX
any pics of what the light output looks like after? (beam spread/cutoff/brightness) lots of pics plz, tank u.
Calling ALL Southeastern and FL members
Originally Posted by TUKO316 View Post
this forum needs to make new members watch an instructional video before their first post.
this effing kid has 27 posts, and about a dozen threads started, wtf? YOU ARE NOT THE FIRST PERSON TO OWN AND WANT TO MOD YOUR ALTIMA...SEARCH FOR YOUR ANSWERS YOU LAZY BASTARD
fun times
Old 11-28-2008, 12:11 AM
Ok, sold. LOL
Can u explain a bit more how-to install/use/run relay then?
Reason i'm asking is because of the light output. I'm not sure if it's supposed to be like that or i'm just too picky, but even thou it's way better then halogens i honestly expected factory hids to be brighter.
Edit: before this thread gets locked and moved to FAQ here's a link to another thread on the same topic in case someone needs to ask more questions 6 months from now.
http://www.nissanclub.com/forums/new...need-help.html
Old 11-28-2008, 07:01 AM
Ok, sold. LOL
Hi, please look in my edited instructions at the top, feel free to ask questions.
to be honest, i keep thinking why doesn't it be much brighter. is not really a big improvement I think, my other Altima have a much bigger difference going OEM. I am guessing is the fact that we have small reflectors and Nissan don't invest much on headlights unlike Toyota and Hondas. If you have a small reflector or space to put in something, at least put in a projector.......just my opinion
Old 11-29-2008, 12:08 AM
im not to sure but did you swap out the whole non HID housing with a housing from another altima equipped with factory HIDs? if so what is the purpose of switching between the two? is there a difference in the reflectors? why not just put HIDs in the the housing you have and call it a day? like i said i wasnt to sure if you actually switching the housings or not but would like to know
Old 11-29-2008, 12:51 AM
the xenon and halogen reflectors are different.
i too did not notice if he said he purchased the xenon housing.
'07 2.5SL dark slate
Old 11-29-2008, 04:34 AM
it is oem halogen interchanged with oem xenon housing. halogen and xenon version have different reflectors
notice the part numbers and the integrated ballasts in the pictures?
Putting hid kit in a halogen housing will product a lot of glare and will result in blinding others on the road because the optics in a halogen and a xenon reflectors are different.
scroll down to the misconception part for more info.
intellexual net · m k i v
