Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2007+ Nissan Altima Discussion > F.A.Q 2007+
  #46 (permalink)
Old 03-03-2009, 11:46 PM
bt2580's Avatar
'Harmony'
Sorry...Been busy
I stopped into my local dealership, and they could not give me a part number for the pins to fit in the fuse box They let me look through all the ones they had, and while a couple might work, I am not sure. They said that they do not have all of them that are available though. I will get out a pair of calipers tonight and measure one, as well as take a couple of photos of it.
And no, you will not find these at Radio Shack...
2004 Altima 2.5 SL
Lighting Sponsored By,
Suspension Sponsored By,
Mod List(won't fit)
CarDomain Page Last updated: 10-26-2009
My Feedback Thread...
  #47 (permalink)
Old 03-04-2009, 01:10 AM
Originally Posted by Mystic2003 View Post
I am glad i decided to read this posting i have been debating to buy the bundle from Courtesy for a while but could not convincce my self but if it works for Vital then it would be great......
Also if you guys find out about the pin in the Harness and where to get it plz share.
You won't really need the pins..all I did with mine is push the wires into the socket in the fuse box..I installed mine for a few months now and it never came off..
2008 Super Black 2.5SL Altima Sedan
15% Around, 35% Windshield, OEM HID, OEM Foglights, Interior & License Plate LEDs, 3.5 Side Mirrors, OEM Style Spoiler, Redout Tail Lights, Clear Bra, Aluminium Kick Plates, Dynamat/B-Quiet (Doors, Rear Deck, Trunk and Floor), Hoodliner, iPod Interface, SBD Grounding Kit, Stillen RSB, Racingline F/R Endlinks and Strutbar, 18" SSR GT3 wrapped in Toyo Proxy 4, Black Muteki Lug Nuts
  #48 (permalink)
Old 03-06-2009, 03:04 PM
Retarted question but i'll still ask - anyway to check if stalk works once i swap it on my car without sticking wires anywere? Is there a fuse that should be "hot" as soon as i turn the fog switch on? (without even having fogs, just the switch)
2008 2.5S w/ conv pkg
18% tint, autostart
OEM 3.5 HID headlights, 3.5 side led mirrors
OEM fogs w/ stalk switch
OEM autodim mirror w/ compass
OEM leather, spoiler
DNX5120 w/ swi-pac & CCD-2000
Polk Audio comps, sub, 2 amps
In&exterior LED swap, dual led turn signal
DEPO led tails
Redline hood lifts
K&N WAI
Stillen RSB
RL's Strut Bar, endlinks, battery tie-down
KONIG FURTHER w/ 245/45-18 Yakohama Advan S.4
  #49 (permalink)
Old 03-06-2009, 04:36 PM
bt2580's Avatar
'Harmony'
Look on the bottom side of the fuse cover...'Fog Light' 15A...I believe.
As to the size of the pins that I have been trying to find. They are 3mm wide and 1mm the other way.
  #50 (permalink)
Old 03-06-2009, 05:42 PM
lol
can u post a link to where i can buy them??
3mm and 1mm doesn't help much when looking for it online let's say.
  #51 (permalink)
Old 03-07-2009, 04:50 PM
So i stopped by dealership to see if they can tell me exactly what pins i should use. Save yourself time - they have no idea.
Servise guy pulled out his "emergengy" electrical repair suitcase with shiiiitloads of pins and connectors and went "pick which ever ones u like" lol
THe only one i could find that are 3mm x 1mm at the end (part that goes inside the deepest) are below. They are small, so my camera couldnt pick up the details the way i'd like to to but here they are. I'm concerned about the "other end" it seems kinda big and bulky. Let me know if they look anything like ones u've used.
  #52 (permalink)
Old 03-07-2009, 04:52 PM
bt2580's Avatar
'Harmony'
Same thing I found at my dealership...And I also could not get a good photo of the damn things...
You need the other end though, that is the piece that is sticking up inside the fusebox already.
  #53 (permalink)
Old 03-07-2009, 05:11 PM
I don't get it. U're saying that the pin in my pics is the one that's already inside the fusebox/socket/whatevr u call it hole that the wire is supposed to be in... right?
If so i can just go back to the dealer and look for a pin that perfectly "clicks" into this one?
Aslo, just to be on the same page: pin i posted is inside the fusebox with 1mm x 3mm DOWN and that bulky end on TOP?
  #54 (permalink)
Old 03-07-2009, 05:18 PM
bt2580's Avatar
'Harmony'
Pull the plug out of the fusebox that was posted back in the OP. Look inside the plug and you will see that you need the 'female' side of that to mate with what is 'fixed' in the fusebox itself. That female pin needs to be put inside the plug.
This is why I haven't reposted a p/n on this pin...It is really hard to find.
As someone else already posted, you can just jam the wires into the plug as well...
  #55 (permalink)
Old 03-07-2009, 07:05 PM
Just went back to the dealer to get female pin. They don't have one that fits into that skinny opening in the fusebox. Neither do AutoZone and PepBoys
And all that running around without being 100% sure stalk will even work haha.
I guess i'll just stick wires in there for now till i find a pin.
bt2580 - thanx for your help. really appriciate it.
I'm getting my fog/stalk kit on monday, pigtails on wednesday so unless weather will fukk me up i'll install fogs on the weekend.
  #56 (permalink)
Old 03-08-2009, 01:56 AM
Seriously guys..you don't need the pins..
