Most modified/built ka? - Nissan Forums : Nissan Forum
Old 03-25-2012, 01:35 AM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
What is the most modified/built ka for the altima you guys know of? I'm planning on making a hell of a fast daily driver so i'm having a spare short block built. Here's what's in the works:
Carillo H-Beam Rods (Con-rod bearings will be clevite with a high performance coating)
CP Pistons 9:1 CR (With Thermal barrier coating)
Consworth Headgasket(abit thicker than stock to bump that CR down just a bit more..)
Stock CrankShaft(Balanced, Micropolished, clevite main bearings with high performance bearing coating)
Stock oil pump (ported)
That's pretty much it. I have heard way too many horror stories of spun rods on hi horsepower ka's so i'm also going to have the stock crankshaft modified to a high speed oil system(basically drilling some more holes for oil keep those damn bearings lubricated at high speeds.)
Pretty sure on all of the above, weakest link i believe will be the pistons, cp is a very good brand but i want the best of the best, any other recommendations? Or is cp as it good an option we have for the ka?
2001 Ka24de (Crower Rods-Arias Pistons)
SC61 Turbo (Currently @17lbs)
AEM Ecu
DMH Electric Exhaust Cut out
MSD 6+/Magnecor Wires
AFC Neo
AEM WideBand
AEM Serial Gauge
2000 5spd Tranny
A.C.T 6 Puck Clutch
Custom Short Shifter
Stillen Strut Bar
ST Rear Sway Bar
Whiteline Front Sway Bar
Racing Line Endlinks
Brembo Drilled/Slotted Rotors
GC Springs/Tokico Struts
18" Centerline RPM's (15lbs!)
Old 03-25-2012, 02:29 AM
Asleep's Avatar
Erect Member
iTrader: 6 reviews
cp is where its at. youd probably get much better info from ka-t.org than this site. more hardcore ka enthusiasts there.
Old 03-25-2012, 03:30 AM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
Yeah good point lol. I'll check it out.
Old 03-26-2012, 03:30 AM
itwillrun's Avatar
all blacked out
CP is good, get manley and get the best.
Mods
Alot
Buy my stuff
http://www.nissanclub.com/forums/par...ml#post4322378
Old 04-08-2012, 02:42 AM
Been a while,thought i would chime in. Pauter machine(not cheap) makes the most durable rod for the ka in my opinion. plus 1 for cp pistons. What kind of power do you plan on making? Just make sure that your tranny gets some love as well, or none of that power will even make it to the cv joints,lol.
447 Whp at 20psi 10/16
Click Below for Updated Mod List & Pics
http://www.ka-t.org/brent_f.php
Link below to thread of 447 whp with vid and dyno sheets
http://www.nissanclub.com/forums/for...wd-ka24de.html
Scott Steven Copp
3-26-82 - 10-11-09
R.I.P
Gone but never forgotten
Old 04-08-2012, 02:56 AM
DIY'er
iTrader: 3 reviews
BRENT!! please fwd me your e-mail. I want to find out how you hooked up the oil return line you gave me.
- Billy
http://www.nissanclub.com/forums/signaturepics/sigpic20104_1.gif
5 and a half inches of clearance w/ 1" wheel gap? Thank you 235/40/18's... Thank you.
Check out my blog!!
http://awdu13.wordpress.com
Old 04-08-2012, 12:41 PM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
I'm really not sure how much power, i plan to raise the boost until i run into tuning problems on 93 octane, because it's my daily driver. I'll go as high as i can as long as i don't run into tuning problems (misfirings, knocking). And i what can i do to my tranny and axles to handle that power? Right now i have spare trannys and cv joints so that's my backup plan lol.
Old 04-08-2012, 12:43 PM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
I want the car to be at the edge of traction on performance street tires, i have an aem with boost control, which can modify boost per gear and rpm, but if i had a number on it, i'd be happy with like 550whp and a reliable daily driver.
Old 04-08-2012, 12:50 PM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
And altimatic i wanted to ask you, what year was your engine? You used the jwt s1 cams right? Did you use the jwt cam gears as well? What did you tune it with? I'd be happy to get 400whp at 20psi on my sc61 turbo, but last dyno we left off at 16psi and it only made 320whp and 330wtq with 2000 stock altima cams..
Old 04-08-2012, 01:59 PM
Asleep's Avatar
Erect Member
iTrader: 6 reviews
i personally dont think youll have many problems with the cv joints. the trans will give for sure - i went thru 2 just under nitrous alone. as for being on the edge of traction - brian easily did that with that car and drag radials. so what happened at the dyno specifically - was there not enough load dialed in? was the turbo just not making any more boost? cody ace had a problem on a dyno that would only let him boost to 19lbs.
Old 04-08-2012, 03:01 PM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
Here's where we started off, i believe the first four runs were 10psi
Old 04-08-2012, 03:03 PM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
Just minor tweaking of ignition timing was done the first three runs, then on the fourth, we installed a cold air intake and there was a huge jump in power and torque
Old 04-08-2012, 03:06 PM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
runs 5-7 we just turned up the boost little by little
Old 04-08-2012, 03:09 PM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
By run number 8 it was clear that raising the boost just wasn't raising power by much.. run #8 i believe had 14psi
Old 04-08-2012, 03:14 PM
F1Altima's Avatar
2750lbs
iTrader: 3 reviews
The last run was @16.5 psi boost, the torque number still stayed very strong. I'm thinking the cams from 2000 altima engine are the least agressive of all the ka's, i definately wouldn't mind trading torque for hp, as well as moving my powerband to the right. I have jwt s1 cams but haven't gotten a chance to install them yet, but i hear their made for a na ka, and i'd need to install jwt cam gears for the s1 cams to work with a turbo.
  Nissan Forums : Nissan Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Forced Induction Forum (Turbo, SC, Tuning)
