Old 11-22-2001, 12:33 AM
Oz Oz is offline
What does the 90,000 mile service entail? nm.
Old 11-22-2001, 01:24 AM
so do you want to know or what?
Old 11-22-2001, 01:48 AM
Oz Oz is offline
Yes. I do understand why you would ask....
Did I make an error in my posted message?
Old 11-22-2001, 01:52 AM
yea..in your title..you put nm..which i thought meant nevermind. anyways..according to the manual you should replace oil, filter, air filter, sparkk plugs, and coolant. you should inspect evap vapor lines, fuel lines, brake lines & cables, brake pads, discs, drums & linings, automatic transmission fluid/transaxle oil, exhaust, steering gear & linkage, axle & suspension parts, steering linkage ball joins & front suspension ball joins, front drive shaft boots, and drive belts. also your fuel filter and top off all your fluids. hope this helps.
Old 11-22-2001, 01:59 AM
Formerly LordofSearchMod
Inspect (replace if damaged):
Drive Belts, EVAP vapor lines, Fuel Lines, Brake lines & Cables, Brake pads-Rotors-Drums-Linings, Transmission Fluid, Steering gear&Linkage, Axle & suspension parts, Exhaust system
Drive Shaft Boots.
Replace:
Air Filter, Coolant, Oil & Filter.
Sparks should have been at every 60K, but its cool to do it 30K.
That is also from the NSM for a 99.
Old 11-22-2001, 02:51 AM
Oz Oz is offline
Thanks. I thought nm=no more (message).
