hard shift from 1st to 2nd - Nissan Forums : Nissan Forum
post #1 of 20 Old 11-24-2003, 08:54 AM Thread Starter
i was just wondering what i could do to fix this hard shift, or what could be causing it. I have 42k miles on the 2001, and i had the tranny fluid drained at 33k miles. just wondering whats up with it.
altimategroundpound is offline
post #2 of 20 Old 12-07-2003, 06:00 AM
Bos
is it 5sp or auto
Boss
Bos is offline
post #3 of 20 Old 12-07-2003, 06:03 AM
Breu Meister
i am assuming automatic. see they 'drained' your fluid but did they actually take off the transmission pan and clean the magnets in it? I would drain and refill the transmission fluid again if i were you. also when i flushed out my radiator and cleaned it and then refilled it, i noticed that the car ran smoother and shifted slightly smoother.
R.I.P. 2000 altima SE
Hello...
2003 Majestic Blue 6 speed maxima
Decoy is offline
post #4 of 20 Old 12-07-2003, 08:42 AM
Resident NICO Mod
Wrong grade of fluid, tarnish in th VB. Just a few things that come to mind.
1995 Nissan D21 Hardbody 4x2 5spd 2.4L.
REVEREND D is offline
post #5 of 20 Old 12-07-2003, 07:42 PM
Well since it's shifting at all right now I assume they refilled your tranny fluid when they were done
That hard shift seems to be all too common on our cars. I've got it too. I hope to be switching to manual sometime in the near future tho, so screw it.
devnull is offline
post #6 of 20 Old 12-07-2003, 09:15 PM
alti97's Avatar
Mine shifts hard from 1st to 2nd in the morning but after a while it gets better. Is that normal?
alti97 is offline
post #7 of 20 Old 12-07-2003, 09:31 PM
I'm The Green Member
enigma94's Avatar
mine does the same. It did it so bad it would eat up tranny mounts like in a month. So i switched to the polly mounts and it helped a little but i think it has to do with the VB being dirty or needing to be cleaned.
" I dont like to use the word US interest, thats why i wish some other critics, friends of ours would stop saying, we go into this country we go into that country we do this and we do that. and i'm like shhh shhh. We dont do anything, they do it to us, we are part of the victims, not part of the victimizers."
enigma94 is offline
post #8 of 20 Old 12-07-2003, 09:43 PM
Breu Meister
mine shifts like a skinny man in butter...
Hello...
Decoy is offline
post #9 of 20 Old 12-07-2003, 09:56 PM
2ndGenAlty's Avatar
mine ran in only 2nd gear today. i thought it was blown. shut it off for an hour, then it worked fine????? i hate autos.
Eibach/KYB-Gr2 - FTSB
2ndGenAlty is offline
post #10 of 20 Old 12-07-2003, 11:24 PM
ars
I'm the drunk member
ars's Avatar
My car has a hard shift from 1st to 2nd
and all the cars that I was testdriving had the same problem like 5 of them
ars is offline
post #11 of 20 Old 12-08-2003, 02:18 AM
Resistance is futile
kierandill's Avatar
Check the dropping resistor - on my first gen it is mounted on the front of the driver-side strut tower by the intake. If it is unplugged, or burnt out, you will have violently hard 1-2 shifts.
This page left intentionally blank - like your head.
kierandill is offline
post #12 of 20 Old 12-08-2003, 02:30 AM Thread Starter
what does this dropping resistor look like? what does it plug into? thanks.
post #13 of 20 Old 12-08-2003, 02:44 AM
kierandill's Avatar
Well its silver and about 3" long, slim rectangular thing. It goes somewhere in the circuit between the control computer for the trans. - if you have a Haynes, it is on 12-24.
The topic of disconnecting the resistor on purpose, or replacing it with a potentiometer, for "performance" shifts came up a couple of years ago. A guy on the Maximas site wired a toggle switch inline, if I recall.
Apparently the hardness of the shift is inversly proportional to the amount of current passing thru that circuit. Breaking the circuit, of course, makes the voltage go to zero. It supposedly has some relationship with the control of the line pressure solenoid valve. Low voltage, and your hydraulic pressure in the trans goes high.
post #14 of 20 Old 12-08-2003, 06:46 AM
Resident NICO Mod
Nissan also had a TSB on hard shifting automatic Altimas. Only some altimas qualified for updated parts. Sadly mine didnt fall under this Customer Satifaction Campaign.
post #15 of 20 Old 12-08-2003, 03:48 PM
Shadetree Mechanic
I've got a hard 1-2 shift as well. It sure doesn't slip in there....feels almost like it grinds. Once the car is heated up it's fine. Maybe I should change the trans fluid to syn.
IBI Wide body and Greddy SP1 catback FS
1993 Altima SR20DET Many mods.
2001 Maxima SE 20th Anniv./Auto
2004 Ford F150 Lariat SCAB Flowmaster/BIG BFG's
jaltima is offline
