does any body know how to change a starter????? - Nissan Forums : Nissan Forum
post #1 of 14 Old 05-05-2004, 01:59 AM Thread Starter
does any 1 here know how to take out n install the starter??(plz teach me)
i believe my starter is dead....it doesnt even have clicking sound when i try to start the car......should i get a brand new 1 or used 1 from junk yard????how much is it going to be.......i hope my alti will get on the street by the end of this weekend.........
nismo~power
nismopower20 is offline
post #2 of 14 Old 05-05-2004, 02:14 AM
Rest in Peace Betsy QQ
get a new starter....goes for ummm...i think mine was like 150 or so....i could be wrong. as far as replacing it, take out your airbox, as you need to get to some bolts on the top of the transmission, and then jack your car up. its not that hard, more of a pain in the arse then anything else.
Originally posted by the1snow1man
My ass dyno says my car felt more responsive and peppy but who knows
Overdrive 97GXE is offline
post #3 of 14 Old 05-05-2004, 02:18 AM
See ya
iTrader: 3 reviews
do a search on this....you need to get to it from under the car, yes, you have bolts on top to reach also. Not easy, but not impossible. Buy a new one with a warranty.
Sassan is offline
post #4 of 14 Old 05-05-2004, 02:22 AM Thread Starter
n how can i make sure the starter is dead?????(may be something else is dead)or the wires is 2 old.....
i m sure i got battery becoz it is brand new......
nismo~power
post #5 of 14 Old 05-05-2004, 02:27 AM
Get a long stick and knock on the solenoid part of the starter. If it starts afterward, you know it's your starter. Keep the stick in the trunk until you replace the starter
LSU TIGERS, BCS and coaches champion !!!
'95 GXE 5spd @211K+ miles
'01 Accord 4cyl @128K+ miles
mike1qaz is offline
post #6 of 14 Old 05-05-2004, 03:19 AM Thread Starter
can i see the starter when i open the hood......???????
i cant even hear clicking sound.....is it the wires or the starter.....
i have no idea.//
nismo~power
post #7 of 14 Old 05-05-2004, 03:27 AM
no you cant see it from above....only from under the car. and if its not clicking, then its your starter. just get a new one. the only way i know of actually checking the starter is taking it in and getting it tested at like advanced discount auto or some place along that lines. Even then, id still replace it, because im like 99.9999% sure from what you have said, its your starter. And make sure you buy brand new too.
post #8 of 14 Old 05-05-2004, 03:43 AM Thread Starter
nismo~power
post #9 of 14 Old 05-05-2004, 04:20 AM
no you cant...you have to be under the car.
post #10 of 14 Old 05-05-2004, 05:07 AM Thread Starter
is there any way i can start the car with the dead starter.....atleast i need to drive the car to the store to fix it......
i don want to pay the tow payment......so damn expensive..
nismo~power
post #11 of 14 Old 05-05-2004, 06:09 AM
get under the car and tap the starter cylinder with a hammer or something....then try to start it....if it starts keep it running....because it wont start again unless ya beat it again if ya stop it.
post #12 of 14 Old 05-05-2004, 12:16 PM
japanese_altima's Avatar
Hey Nismo, i gotchu on this... alright well im new to this altima.net thing so yea this mah first post trying help you out... ayte its like this well if you want your car to the autoshop its either wat everyone else sed, tap the stater or if your car is manual you can had someone push while its on first gear and quickly pop the clutch and it should start.... ayte well if you really need to change the starter its about $150 -$200 so yea if you really want a new one you could go that way or if not.. go look for a junked up altima or used parts i just recently change mines about a week ago i got mah starter for $60 and i put it in mahself.... ayte you cant see the starter when you pop the hood it right under the engine. between the engine and firewall... its under there some where it should look like this
http://i23.ebayimg.com/02/i/01/c5/55/81_1_b.JPG
if you locate it and tap it and doesnt work and you can get someone to fix it for you or fix it yourself. it took me about less then an hour to do it... but yea its a pain in to get it out... alrite well to replace it theres 2 long bolts holding it in place and one that connects to the battery. before you start at it be sure to take the neg wire off the battery so you dunt kill yourself. well to get started you either need a lift or the hard way get a jack and just jack it up and go under. you should first disconnect the electrical wires. then start taking the bolts off. you can do this from the top of your car to make room you can take your intake box off or watever kind of intake you have. this will give you more space. you need a long sockect wrench to take the two bolts off. after doing this you replace it with the new one you change have someone help you hold it in place while you screw the bolths back on or you can get something to wedge it there for you. ( i used some rags to hold it in place) then connect the electrical back on and the battery and you should be good to go.
Mah car is different from yalls but it should still be the same i had an SR18 engine and swap a SR20 starter to it. i have a nissan bluebird not an altima but its almost exactly the same so it should work.
alrite well good luck on this yo.
japanese_altima is offline
post #13 of 14 Old 05-06-2004, 01:36 AM
RIP FRNT2BK Feb 29, 2008
NOTORIOUS170's Avatar
Get yourself a Chiltons manual. That things got all the info. For added assurance, I bought that and the Haynes.
NOTORIOUS170 is offline
post #14 of 14 Old 05-06-2004, 01:45 PM
i'm RICH BITCH!!!
arthur early's Avatar
I have one for sale 150 shipped it yours
arthur early is offline
