How much for a valve adjustment??? - Nissan Forums : Nissan Forum
post #1 of 21 Old 07-17-2004, 04:55 AM Thread Starter
obeyforiamroot
Exclamation How much for a valve adjustment???
ok, im sick and tired of the clanking noise when i turn on my car, sometimes it goes away and sometimes it doesnt. If i don't adjust my valves and let this go on will it get any worse? will it lead to instanses causing danger to the motor? Has anyone gotten their valves adjusted? if so how much will it run me?
Thanks in advance
Speed kills; get a honda, u'll live forever.
Registry: http://www.nissantalk.com/registry/vehicles.php?vehicleid=3014
qbase216 is offline
post #2 of 21 Old 07-17-2004, 05:24 AM
The Dude
ULTIMATUC's Avatar
we have hydraulic lifters.....no need for adjustment.
ULTIMATUC is offline
post #3 of 21 Old 07-17-2004, 05:44 AM Thread Starter
obeyforiamroot
well is there anything i can do about clanking valves? this only happens when the car is cold, and the whole oil not getting to the valves is bullshit. I dont see new cars starting their engines and hearing the valves destroy themselves (its that loud). The moment i start the car i can hear the noise with all doors closed and music playin. It goes away after about 10 min of drivin but even then the engine doesnt sound right (still a little clankin). I have heard people with altimas doin valve adjustements....if not than what can i do?
Thanks
qbase216 is offline
post #4 of 21 Old 07-17-2004, 06:08 AM
The Dude
ULTIMATUC's Avatar
its prolly your timing chain that youre hearing. if its not the chain, you need to check how much oil pressure you have.
post #5 of 21 Old 07-17-2004, 06:22 PM Thread Starter
obeyforiamroot
the timing chain noise doesnt go away as the car warms up. How do i check oil pressure? (the oil level is fine)
qbase216 is offline
post #6 of 21 Old 07-18-2004, 05:43 AM
it could also be your oil pickup... mine was making a loud clanking noise till i got my oil pickup cleaned out.
Got Chrome ?
http://webpages.charter.net/k4hscorpion/
k4hscorpion is offline
post #7 of 21 Old 07-20-2004, 04:04 AM
" the manufaturer recommends adjusting the valve clearance at specified intervals if the valve train is excessive noise." Quote from Haynes 93-01 nissan altima all models.
spyrofire20 is offline
post #8 of 21 Old 07-20-2004, 02:46 PM
RIP 6/24/07
Even with hydraulic lifters you still have to adjust them.
Originally Posted by SLOW KA_
haha..I really get a kick out of people trying to turn the KA into some kind of high revving monster,like power is going to mysteriously appear because you add short runners on the mani,high compression pistons yadda yadda yadda...like these things havent been discussed to no end.
Everyone who is serious about having a "fast" KA is either FI or N20 equipped.SHAWN is the exception to that though.
Go forced induction or squeeze,or go home.
Eccho is offline
post #9 of 21 Old 07-20-2004, 07:24 PM
Import Tech.
SHAWN's Avatar
WRONG !! We do NOT have Hydraulic lifters ... KA24DE uses a shim type valve adjustment , Cost wise its about $90 to check them , if any need adjustment then it gets expensive .... I would say the average is around $200 ..... But from what is stated , it does sound more like an upper tchain guide noise , Nissan has a bulletin that says to remove both upper chain chain guides ..... I would say have a good shop remove your upper chain guides, then check the valve clearances while the valve cover is off .... If they are close , leave them be , but if any are way off , then you will want to have them done .....
SHAWN
Auto Shop Northwest O.C. OR
'09 Sentra FE+ Driver
'14 Crosstrek Wifes
'98 Sentra SE Time Attack
'09 Titan CC LB SE
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #10 of 21 Old 07-20-2004, 10:53 PM
The Dude
ULTIMATUC's Avatar
^ we dont have plunger style lifters?
at what intervals would you say they need to be shimmed?
post #11 of 21 Old 07-20-2004, 11:05 PM Thread Starter
obeyforiamroot
i have a 98 and i have hydraulic lifters, no clue what ur talking about
qbase216 is offline
post #12 of 21 Old 07-21-2004, 12:41 AM
Import Tech.
SHAWN's Avatar
Um, No you dont know what you are talking about , how many KA24DE heads have you had appart ? Believe me , I have done reshims on mine about 10 times , with the TopEnd Performance regrind cams , and a fresh head, you have to reshim alot to get it just perfect !!
They should be done only if noisy or every 60K or so ... they dont wear , so they dont go out of spec very often ......
KA24DE's have no sort of Hydraulic lash adjustment , the SR20DE does ( and even those have a valve adjust procedure ) , but the KA is a full solid lifter engine ...
SHAWN
'14 Crosstrek Wifes
'09 Titan CC LB SE
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #13 of 21 Old 07-21-2004, 12:54 AM Thread Starter
obeyforiamroot
thats just what i was told by a mechanic, he said both ka and sr20 have hydraulic lifters, guess he didnt know. i dont get much noise when the car is warm but it really rattles when cold. NO its not the timing guide that sound doesnt go away. This sounds like a chain getting pulled over a metal bar, it gets quiter and louder periodicly until it dissapears after tha car has warmed up. Why is it so expensive to adjust the valves?
qbase216 is offline
post #14 of 21 Old 07-21-2004, 02:51 PM
Import Tech.
SHAWN's Avatar
To replace the shims you have to remove the cams , that takes time .. The adjustment requires you to check the clearance , if its off you replace the shim with a different thickness shim , the shims are like $8 ea. from Nissan , but the cams have to come out to replace them .... I will say if you do have the valves done , remove the guides anyways ... not to much more work after the valve cover is off You noise sounds like the guide issue ... But yea, usualy that gets most noticeable when warm ..
SHAWN
'14 Crosstrek Wifes
'09 Titan CC LB SE
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #15 of 21 Old 08-09-2004, 03:55 AM
Another Boosted Altima
Not trying to hit up all these old threads. But i been searching and reading and they all have to do with each other. Shawn, you said that you should reshim the valves about every 60k or if excessive noise. Well my car is about 115k and i really doubt that they have been re-shimmed. I am planning on taking off those dam tc guides and i am wondering if i should go ahead and check the clearences on the valves. That and is there anything else i should do while i have the valve cover off.
Special-K
And the name is supposed to be vader3120. F*** IT!
1997 Altima KA24DE-T RIP
1991 SE-R SR20DE - For Sale
-Tranny Swap Done (JDM B13 VLSD & JGY LSD)
2004 Jetta 1.8T - Daily Driver
-FMIC, Turbo Inlet Pipe, 3" Turbo Back Exhaust
vaser3120 is offline
