Clutch Install For 1996 Altima - Nissan Forums : Nissan Forum
post #1 of 6 Old 11-24-2004, 11:04 PM Thread Starter
I was planning on buying a 1996 Altima SE. The only catch is that the clutch is blown out. I was wondering how hard it would be to install a new one. I would be working in my garage and have the ability to work on it. I was wondering if it would be fairly easy to change it or would it be hard? Any help would be appreticated.
LedZeppelin is offline
post #2 of 6 Old 11-25-2004, 12:01 AM
Import Tech.
SHAWN's Avatar
If you have not done one before , I dont suggest trying it in your garage , you can really screw things up ....And its no easy task ...
SHAWN
Auto Shop Northwest O.C. OR
'09 Sentra FE+ Driver
'14 Crosstrek Wifes
'98 Sentra SE Time Attack
'09 Titan CC LB SE
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #3 of 6 Old 11-25-2004, 12:33 AM
Moose Trainer
I replaced an axle in a parking lot this weekend, and I didn't really have any prior experience working on cars, so anything's possible.
That said, clutch is pretty major. I think you have to take the tranny out to get to it, which will require taking both axles out. Once the clutch is out, you'll probably need to replace the disk, have the flywheel resurfaced, and do something with the pressure plate.
Check out a Hanes manual for a general description of the job, and then find a real shop manual if you still want to try it. Plan on it taking a lot longer than you think it should, and plan on spending a good bit on parts and tools you didn't think you'd need.
Have fun!
NCWolf is offline
post #4 of 6 Old 11-27-2004, 07:49 PM Thread Starter
ttt
post #5 of 6 Old 11-30-2004, 09:41 PM Thread Starter
ttt
post #6 of 6 Old 12-01-2004, 12:34 AM
2nd gen slayer :)
follow this link and it will take you to the fsm which would break down the install for you http://www.nissanclub.com/forums/sho...d.php?t=177639
whoa353 is offline
