Disable factory alarm? - Nissan Forums : Nissan Forum
post #1 of 6 Old 01-05-2005, 12:24 AM Thread Starter
975Altima's Avatar
Question Disable factory alarm?
I have a 97 and want to disable the factory anti-theft device. It is more throuble than is worth. Many times I come to find my car with the headlights flashing, and neighbors call to tell me also. It wears the battery and I don't want to get stranded this winter.
It is as if the littlest thing sets it off. Luckily it doesn't make noise!
The dealer was no help.
Anyone know if it is as easy as pulling a fuse or cutting a wire?
1997.5 Limited Edition GXE, traded in for 2005 Sentra 1.8 Special Ed
975Altima is offline
post #2 of 6 Old 01-05-2005, 03:04 AM
93 Altima Owner
tuffbird's Avatar
Have you tried pulling the relays (block on passenger side, 3 relays sit there for the anti-theft system 1 Inhibitor Relay sits in the relay block next to the battery) or disconnecting/pulling the ATS control module (under driver side kick panel, should be behind the ABS module if you have ABS).
Not sure but those would be my first steps...haven't had the opportunity to disable one yet.
tuffbird is offline
post #3 of 6 Old 01-05-2005, 09:01 AM Thread Starter
975Altima's Avatar
Thanks, I will try those suggestions!
post #4 of 6 Old 01-06-2005, 12:59 PM
Altimaboy
SexyGXE's Avatar
Are you sure you have a factory alaram? You said the littlest thing sets it off. Why is that? Factory alarms don't have shock sensors. Only way it would go off is if a door were open. I would reccomend checking your door switches, and your hood switch. I would keep my alarm.
The thief comes only to steal and kill and destroy; I have come that they may have life, and have it to the full.
John 10:10
SexyGXE is offline
post #5 of 6 Old 01-07-2005, 05:48 AM Thread Starter
975Altima's Avatar
I will double check. I know that one time I set it off when I reached in an open window and unlocked the door. It was thinking someone smashed in to open the car.
It could be door switches. I may just go to a shop that specializes in auto secuity just to have it looked at.
post #6 of 6 Old 01-07-2005, 02:50 PM
Altimaboy
SexyGXE's Avatar
That is what it is supposed to do. The alarm will go off if any of the doors, hood, or trunk is open 1) without the key 2) without the keyles remote 3) without poping the trunk, or hood from the inside
John 10:10
SexyGXE is offline
