Door won't open - Nissan Forums : Nissan Forum
post #1 of 10 Old 01-28-2005, 01:47 PM Thread Starter
Question Door won't open
I have a '98 GXE and now the rear passenger won't open from the inside but will from the outside. The child lock isn't set. The only other thing I've noticed is when I engage the lock switch on the driver door to lock them all, sometimes I'll get a groan like sound, but they will all lock.................any help is appreciated.
grogman1 is offline
post #2 of 10 Old 01-28-2005, 01:56 PM
Try WD40/PB Blaster in the lock. I trust you haven't greased or done that before?
1997 Altima XE
KYB GR2/Eibach Springs/Stillen (Susp Tech) Rear Sway/Taz's 1st Set of Rear Endlinks/Camber Bolts/Silverstars (upgrd'd ends)/2x Kicker Impulse 12" Subs/Jensen 500w 2ch/Ebay FSTB/Brembo Slot Front w/cer PBR Ultimate Pads/New OEM Clutch/New Alternator/Nismo Oil Cap /SWA Battery Bar/Liquid Ink A-Arm Brace (Blue)/Viper 791 2way-Rem Start
*On Order*
PR CAI
*To Install*
AEM Bypass
*To Order*
H&R Springs/New Mounts/New Bushings
All Done in my garage.
slippy4twenty is offline
post #3 of 10 Old 01-28-2005, 01:56 PM
Altimaboy
SexyGXE's Avatar
The handle could have came off the spring. Can you feel any tension in the handle? It should be a lot of force on the handle.
The thief comes only to steal and kill and destroy; I have come that they may have life, and have it to the full.
John 10:10
SexyGXE is offline
post #4 of 10 Old 01-28-2005, 01:58 PM Thread Starter
No I haven't done anything yet - I'll give it a spray. Yeah the tension is still there, when i pull the inside latch, I can see parts moving.......................
grogman1 is offline
post #5 of 10 Old 01-28-2005, 05:11 PM
Ex 1st gen owner
stealthmode20's Avatar
move the child lock back and forth a couple of times, then try
stealthmode20 is offline
post #6 of 10 Old 01-28-2005, 05:43 PM Thread Starter
Funny you mention that Dru. That seems to be where the problem might be. I was just working on it outside and when I engage and disengage the child lock then try to open the door from the inside, it looks like that's what is stopping it from opening. Problem is that it's so friggin' cold here that I can only work on it at 10 minutes at a time.......................................I also sprayed a little WD-40 on the latch and the child safety lock, but no luck yet.............................still won't open.
Update: I worked with it some more and I don't think that it's being caused by a malfunctioning safety lock or door latch because I compared how the lock and latch function on the other rear(working) rear door and they both appear to be the same. Hmmmm any idears?
grogman1 is offline
post #7 of 10 Old 01-28-2005, 09:31 PM
Ex 1st gen owner
probably the linkage inside of the door, you'll need to take off the door panel
post #8 of 10 Old 01-28-2005, 09:32 PM
Ex 1st gen owner
check the linkages around the child saftey lever
post #9 of 10 Old 01-29-2005, 04:10 PM Thread Starter
Thanks - I'll take a look and post back.
grogman1 is offline
post #10 of 10 Old 03-07-2005, 02:09 PM Thread Starter
Just to close the loop on this one, I had a chance this weekend to take the door panel off and have a look as it finally hit 60 degrees here. Anyway the problem turned out to be with a plastic guide clip for the metal door rod. When I would pull the inside door handle to try to open the door, the plastic clip would start to rotate counterclock-wise and jam the rod. Stopping the rod from engaging the latch. Anyway, a little WD-40 and some grease on the rod and clip and we're good to go. I love it when it turns out to be nothing.........................................
grogman1 is offline
