Replaced alternator and brake/battery lights still on - Nissan Forums : Nissan Forum
post #1 of 12 Old 02-17-2005, 07:51 PM Thread Starter
24D
Hello everyone after doing a search I found that when the battery light and brake light come on at the same time that the alternator is about to go. Well I replaced it with an OEM alt. and turned on the car and both lights still came on. What else could be causing this? Any help would be appreciated.
FYI
It's a 1996 Altima
I don't have a system
The brake fluid level is fine.
Thanks
24D is offline
post #2 of 12 Old 02-17-2005, 07:56 PM
Breu Meister
Quoted: 1 Post(s)
possibly a relay; also check fuses and connections to your battery.
R.I.P. 2000 altima SE
Hello...
2003 Majestic Blue 6 speed maxima
Decoy is offline
post #3 of 12 Old 02-18-2005, 10:25 PM Thread Starter
24D
Has this happened to anyone else after replacing the alternator. The brake and battery light staying on, I mean.
24D is offline
post #4 of 12 Old 02-18-2005, 10:28 PM
Member
TPhelps155's Avatar
Yes, meaning the alternator is still bad (the new one you got).
Was the new one rebuilt? If so my guess its that. Happened to me. I dont know what else it could be.
TPhelps155 is offline
post #5 of 12 Old 02-18-2005, 10:33 PM
coach's Avatar
would resetting the ECU help?
coach is offline
post #6 of 12 Old 02-18-2005, 10:42 PM
The Don.
Quoted: 5 Post(s)
No, because the ECU does not play any part in the circuit.
If the battery/brake light is still ON then the "new" alternator must be bad or has gone bad.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #7 of 12 Old 02-18-2005, 11:04 PM
Quoted: 7 Post(s)
There's probably an extremely good chance it's bad if it came from:
1. Autozone
2. Advance
Any other chain store that sells similar quality electric crap...
I've always heard NAPA, CarQuest, O'Reilly's(suprising) have decent alts/starters, etc, depending on the area...
And if the store offers a Lifetime warranty, usually there's a good chance you'll be replacing it for a lifetime...
Jeremy
niceguy is offline
post #8 of 12 Old 02-18-2005, 11:15 PM
Have you tried a volt meter on battery? Check volts before starting then after its started you should see an increase in volts to around 14.5 if alternator is good.
silverdouble is offline
post #9 of 12 Old 02-19-2005, 01:12 AM
Import Tech.
SHAWN's Avatar
Batt and brake light on when the car is running is Alternator ... or you have a short to ground on the wire ...
SHAWN
Auto Shop Northwest O.C. OR
'09 Sentra FE+ Driver
'14 Crosstrek Wifes
'98 Sentra SE Time Attack
'09 Titan CC LB SE
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
post #10 of 12 Old 02-19-2005, 09:47 PM Thread Starter
24D
I got the alternator from a Nissan dealership. And I tried resetting the ecu. On the short to ground on the wire do you mean the wire coming from the alternator, I'm guessing the wire that screws into the back using a small phillips head screw is the ground wire. It would definately suck if the new alternator is bad especially since it came from the dealership.
Thanks for the replies. I should have known it wasn't going to work since I didn't have a very hard time replacing it. If you guys have any more ideas please post.
24D is offline
post #11 of 12 Old 02-19-2005, 11:23 PM
coach's Avatar
you should have some type of warranty from the dealership on new parts if they are DOA. just take it back and get a new one
coach is offline
post #12 of 12 Old 02-28-2005, 03:26 AM Thread Starter
24D
Can anyone enlighten me on what ground wire I should be looking for? Or should I add an additional ground? Thanks
24D is offline
